Buying Advice Using 3pt hitch on the BX25 vs B2320
   / Using 3pt hitch on the BX25 vs B2320 #11
I don't think you will be able to run a 6" chipper with a 23 HP tractor.I previously had a BX25 with a Wallenstein 4" chipper.That was the maximum size that the dealer reccomended for the horsepower.
Well I'm going back to the dealer today. After considering all the advice, I'm strongly leaning toward a B2620 and just biting the bullet and getting the BH65 from Kubota. There's just no clear winner and it seems either one would do a good job. I know the B would do better but the BX is such a good deal!
Thanks for all the tips.
   / Using 3pt hitch on the BX25 vs B2320 #13
After hearing all the advice, I'm strongly leaning toward the B.
1*I was looking at an after market back hoe that mounts to the 3PT hitch.
2* but it might b a good compromise for the Wallet.
1.See 3*
2*There have been people crushed when something suddenly breaks on a 3 point BH.
I don't like those kind of compromises.
3*No way I'd put a backhoe on the 3 pt.
4* I don't like broken tractors, period.
3*Me neither.
4*Broken bones and crushed skulls aren't so good either.
   / Using 3pt hitch on the BX25 vs B2320 #14
I previously had a B2410 (smallest of the B series) with a Woods 6500 subframe mounted backhoe and have used my fathers BX. For a lawn mowing machine the BX with turf tires would be more manueverable than the B. Once you get off road the small BX tires, limited ground clearance and underneath fan really limit the BX.
How big are the stumps you want to pull up? If the trees are only 1-3 inches you may be able to just pull them out with the drawbar. If they are 12+ inches you will be spending lots of time digging around them to pull them out with either tractor. Can you skip the backhoe and rent a mini excavator for the tree removal project.
I agree with the others. A backhoe can really stress the back end of a tractor. I would onlu use a subframe mounted backhoe on that size machine. I also used a Wallenstein BX42 with the 2410 (18 pto hp). It worked but really didn't have the power for full 4 inch logs.
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
CAT 930M (A58214)
CAT 930M (A58214)
