DieselPower
Elite Member
- Joined
- Sep 30, 2006
- Messages
- 2,756
- Location
- Fairfield, PA
- Tractor
- JD 3020, JD 4230, JD 7410, JD 2440, MF 750, NH LS170
joerocker said:Is the additive package THAT important?
Then why isn't it part of the oil spec?
I think it's all marketing hooey... IF the additives ARE imperative (as many of you believe) it would be part of the specification...correct? If they're not (as me and others think) then they're not in the specification and are unneeded...correct? What I'm saying is that the standards for oil increase all the time, SA, SB, SJ, whatever...so with all that increase in the standard, why isn't there an inclusion of somebody's "additive package" if it's THAT good?
Name brand or generic...all the same thing except the profit. As long as it meets the standards. These arguments about Chinese and Indian knockoffs are ludicrous. We're NOT talking about knockoffs or illegal inferior imports, we're talking about American made products, meeting the standards.
If I understand correctly...the difference between dino and synthetic oil is simply this: Dino is crude broken down to become whatever viscosity the oil ends up being. Synthetic is crude broken WAY down and then "built up" to be the thicker oil it ends up being. It's STILL plain old crude turned into oil. Close enough description?
Believe what you like but the additive package is one of the key factors that makes one lubricant superior to another. High end oils can have as much as 5 times the additive package when compared to their cheap counterpart. Hydraulic/UTF type oils are a good example. A cheap oil may only pass the oxidation test at 1,000 to 2,000 hours while a high end one will go 10,000+ hours. What's the difference, the base stock and additive package. You get what you pay for.
"What I'm saying is that the standards for oil increase all the time, SA, SB, SJ, whatever...so with all that increase in the standard, why isn't there an inclusion of somebody's "additive package" if it's THAT good?"
I'm not sure if I completely understand this question but here goes. When oil spec's are "updated" from lets say CI-4 to CJ-4 they are very different. The newest CJ-4 engine oils are a good example. They are the most drastically different change in engine oil formulation since the inception of the API rating. It cost around $520,000 to get a engine oil certified CJ-4. Add multi-ratings like CJ-4/SM and the cost of certification goes up to about $840,000. Oil is very expensive to formulate and test.
So, every time a new more modern certification comes out all the manufacturers have to update (reformulate) their oil to meet the new spec. It's not that their old oil meets the new spec, it's a whole new oil formulation.
