Wanted 40+ HP 4wd Tractor with Factory Cab...Which one to buy ???
   / Wanted 40+ HP 4wd Tractor with Factory Cab...Which one to buy ??? #11
I was kind of in the same boat. That's the problem. Machines tend to become more application specific. You can't have one, that does all well. I had a compact with a belly mower, but after a while realized it wasn't good for rough cutting, and didn't do a fine cut either, if for no other reason, that you drive over the grass before you cut it. I also found the ground clearance limitations of the belly mower to be a problem when working in rough terrain.
I was diappointed that Kubota didn't offer a back hoe that one could opperate from inside that gorgeous cab!
And JD only offers a goofy five foot front mount blower on their compact cab tractor!
It's enough to drive one crazy:eek:
Thanks for all of the input , it is a tough situation, I am going out to my local Kubota John Deere and New Holland dealers today. The Kubota BX 24 that I have now fits the bill, But in my opnopnit does not have enough power, But as many of you have suggested it might be best to have a dedicated grass cutting machine , and a tractor for the rest. Earlier before my post I had looked at a John Deere 3720 or a 4320 with Cab, and a New Holland TD45DA with Cab. They were both nice units, I had alos looked at the new Cub Cadet Yanmar EX3200, But id did not have the Cab as of yet. I also was impressed with the Mahindra'a. Does anyone have any suggestions on the JD or The New Hollands, or a Mahindra. likes or dis-likes.
   / Wanted 40+ HP 4wd Tractor with Factory Cab...Which one to buy ??? #13
Comment on the Cub Cadets - Don't buy it.
Not that it's a bad machine, but Cub has a very poor history of dabbling in this segment. I really don't think that they are going to still be selling them in 3 years, nor supporting them. Maybe they will, but that's not the history.
The mahindra's have a strong following - they are a bit rough around the edges so to speak when compared to Kubota / Deere, but good machines still.
Have you looked for a 8-12 year old 50-75 hp cab tractor? Probably can get one for less than the 3720 or 4320 cab machines.
   / Wanted 40+ HP 4wd Tractor with Factory Cab...Which one to buy ??? #14
I vote for a separate mower, New Holland tractor with a subframe mounted Woods 90 backhoe, of course that's what I ended up with.....I just didn't get the cab yet because of all the brush I have to clear. If you get the 3pt hoe, you'll probably be disgusted eventually.....I agree with Bob earlier.......the mmm will be a pain and not efficient with the setup at all.
   / Wanted 40+ HP 4wd Tractor with Factory Cab...Which one to buy ??? #15
7021 (A55851)
7021 (A55851)
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
Sedan (A59231)
Sedan (A59231)
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
