Wanted: First and Last drill press I'll ever own
   / Wanted: First and Last drill press I'll ever own #21
I have a 30+ year old craftsman floor standing. Easy belt changes for speed control, a cast iron table and base and it has been good to me. I think the bearings are going out and my dream is to get a reasonably priced mill as a replacement. Got my eye on some grizzly models but when I do the math and try to justify it, I can't. But I know once I retire and have the time to enjoy it, I won't be able to afford so... I should pull the trigger soon! :D
   / Wanted: First and Last drill press I'll ever own #22
I scored the heaviest Harbor Freight floor model off Craigslist for $60. No problems in 3 years. I would like to get a decent mill but they are hard to find locally used.
   / Wanted: First and Last drill press I'll ever own #23
I vote for a mill-drill tool.
   / Wanted: First and Last drill press I'll ever own #24
This is what I have done and I am by no means suggesting it is the best way. Just saying that it works for me.
I TRY to purchase older quality bench top DP's and refurbish them if necessary (most often the case.). I'm pretty certain I have UNDER $200 invested in the drills in the first picture.
For REAL heavy drilling a mill drill or mill (as others have mentioned) works well though.
My drill press table crank is stripped out. I'll be stealing your idea on the trailer tongue jack idea.
   / Wanted: First and Last drill press I'll ever own #25
Hopefully this will save you a little time:
I couldn't (or was too lazy to) remove the table assembly or headstock from my press. I had my bearing supplier special order (yours may NOT need to) SPLIT locking collars to match my column's diameter.
I welded a handle to one setscrew.
The collar can then be used for fabricating your mounting bracket.
   / Wanted: First and Last drill press I'll ever own #26
IF you go that route, at the very least get a small, cheap big box store drill press. I got this one used for $20 and keep it set up with a step drill.
I use it whenever possible for holes up to 1/2" in material UNDER 3/16. It's just the way I LIKE it... Quick & Dirty! (oops I didn't say that out loud did I?...)
   / Wanted: First and Last drill press I'll ever own #27
You sure do show off a lot.
Just kidding, It's awesome! :drink:
   / Wanted: First and Last drill press I'll ever own #28
   / Wanted: First and Last drill press I'll ever own #29
I had some broken/stripped bolts in a pump that occasionally re-occur (design weakness.) I was using a hand drill to drill a hole, then insert an EZ out spinning in reverse to get the broken bolt out. But sometimes my aim was bad and if I was a little off I ruined the threads in the pump while trying to get the bolt out.
My solution was to buy a Craftsman drill press from Sears. Since I always wanted a drill press, I bought the top-of-the-line most expensive model. It's heavy and lugging it home and setting it up was a chore. Laser sights and all the goodies.
When I fired it up, that's when I learned it doesn't operate in reverse. :mad:
Doh! You can still turn it, in reverse, by hand.
   / Wanted: First and Last drill press I'll ever own #30
You need to see if the chuck can be removed easily. On mine if you drop down the spindle there is a slot to put in a drift to remove.
I have an older drill press that has a taper fit in the spindle and a "taper to Jacobs chuck" adapter, then the chuck.
When I got it new the chuck kept falling out of the spindle. I put the adapter w/chuck in the freezer for a while then put it in and it has stayed.
You might just be able to remove and reseat it.
Agree. Try this before returning.
PALLET OF MISC (A58374)
PALLET OF MISC...
Giyi Excavator 44" Rake (A57149)
Giyi Excavator 44"...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
Meyer 8.5' Snow Plow (A55272)
Meyer 8.5' Snow...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
4PC OF PVC PIPE - APPROX. 36" (A58374)
4PC OF PVC PIPE -...
