Welcome to my Nightmare!!!!
   / Welcome to my Nightmare!!!! #181
This is a great thread Eddie! I've been lurking (and learning) as I have not had anything more to offer than Plowrup and the other guys. I know that the liquid nitrogen can work wonders to help get out old sleeves and to install new dry sleeves with as much as a few thousandths interference fit. I'm guessing your wet sleeves went in easier than pulling the old ones out?
I wonder if these engines last as long as say a JD 6cylinder that is common to get 7000 hours or more out of them??? I sure hope so. It is good that you are documenting the overhaul in case you ever sell it. I hope you have some shade to work under. Good luck getting her going. Be careful on the valve setting/timing. Not Cool if you get it out of sync.
   / Welcome to my Nightmare!!!! #182
   / Welcome to my Nightmare!!!! #183
<font color="blue"> I hope you have some shade to work under. </font>
Would that make Eddie a shadetree mechanic? /forums/images/graemlins/blush.gif
Eddie, Your ambition to learn, and then to share your creativeness and successes are admirable.
Don
   / Welcome to my Nightmare!!!! #184
Don
   / Welcome to my Nightmare!!!! #187
I agree, this has been a great learning experiance for me. Thank you Eddie for taking the time to detail this for us. I have started projects before where the task seem more than formidable and now it seems you are starting to see the light at the end of the tunnel . /forums/images/graemlins/grin.gif
This website has to be one of the most useful and productive that I have come across. Cheers to all involved /forums/images/graemlins/grin.gif
Puck
PS I am thinking about printing this whole darn post to keep in the filing cabinet. It would be hard to find a book with so much info.
   / Welcome to my Nightmare!!!! #188
Puck
   / Welcome to my Nightmare!!!! #189
One thing I learned the hard way was the value of wet sleeves over dry sleeves or no sleeves at all. I had a tractor that had to have the dry sleeves replaced and they were the thin type, I believe they are called tin can liners. Anyways, I had to split the tractor and take the entire engine to the shop to have the sleeves replaced. If it had wet sleeves or the normal dry sleeves I could have done it in my garage. It is now on my list of things to check if I ever get another piece of field equipment to make sure that it is field serviceable. Most of these compact tractors on this board are not. I realize the odds are slim to none that you would need to do something like this to one of these modern works of art but, like in my case, sometimes slim shows up. /forums/images/graemlins/tongue.gif
   / Welcome to my Nightmare!!!! #190
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
Trommel (A52377)
Trommel (A52377)
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A55218)
2015 Freightliner...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
