EddieWalker
Epic Contributor
</font><font color="blue" class="small">( You do not cool or freeze WET sleeves when installing in the block. All this talking of chilling them is for DRY sleeves only as they can be as much as .005" interferance fit.
When installing a wet sleeve you clean out the step at the top of your block and the sealing surface near the bottom, lube your seals with liquid soap and set that puppy in the hole. It will freely go till the sealing rings (o-rings) contact the bottom of the water jacket. Check your sleeve for proper index with the crank (notches in bottom of sleeve). At this point lay a peice of clean hard wood across the top of the sleeve and while holding the wood tap the sleeve home. Do not hit it hard, just gentle raps with a 2LBS hammer.
You could also make a fixture that will bolt to the top of the block going across the sleeve and push it down with a small hyd jack. )</font>
OK, sounds like you know more about this than the rest of us and you're the first and only one to mention there is a difference between wet and dry sleeves.
Mine are wet sleeves.
Will freezing them help at all? Or is this strictly a technique used for dry sleeves?
I've been looking in my two refrigerators and stand up freezer to find space to put six sleeves, with some serious head scratching going on. Harvey got me wondering about space for all those sleeves and how long I need to leave them in the freezer. If I don't have to do this, I can start assembly tomorrow after I pic up my parts and not wait until Wednesday for them to freeze.
I also didn't notice any "O" rings, but they could have been destroyed coming out, or do they melt to form a seal from the engine temps? Could it just be a term and not really look like "O" rings that I'm familiar with?
I'm also wondering what everyone uses to lube the head bolts? Any recomondations?
Thanks.
Dave,
The parts of the picture you circled are surface rust like a film from an early morning downpour. I sprayed it with JB oil and wiped it all down. I was thinking of you when I first got started, so took the picture first, then put away the camera before getting dirty. Steph says she's never seen anybody get as dirty as I do!! /forums/images/graemlins/grin.gif
Eddie
Thanks.
Dave,
Eddie
