Welding Up a Cracked Rim
   / Welding Up a Cracked Rim #51
i've epoxy seled rivited rims from the inside before... after drilling and weldign the cracks out of course.
good epoxy paint over appropriate rust control or epoxy primer after rust cleanup is a great treatment too
   / Welding Up a Cracked Rim #52
I think I'm gonna go out and weld on a rim.. just because. I'm feelin lucky today.. :)
OK, but don't even THINK about washing any parts in gasoline, or welding
on any ROPS, SG. :)
   / Welding Up a Cracked Rim #53
on any ROPS, SG. :)
rops are golden to me. them I won't fudge with too much. i won't drill or weld them. that's just my comfort level there. ( i generally don't advise others to do it either.. as with anything.. owners are free to do whatever they wish with their own equipment.. just be sure to tell a next owner if you have modified a safety part though :) ) on the other hand.. 80% of my machines don't have rops at all.. though i am slowly outfitting the ones I use most with rops, as I find them.
gas as a parts wash? yuck. flashes off too fast and is smelly... I much prefer diesel, if at all available... ;)
not that I semm may tractors.. but if I did.. I'd reveal any weld repairs made to structural or other parts of the machine. if nothing else to show them the reapir was done well.. and not a previous hack job or cover up.
i'm into full discolsure. i don't mind buying repaired stuff either.. i just like to hear about it when making hte purchase decision. :)
as for rims.. I've bought many tractors that had softdall sized holes inthem with tubes and boots poking thru like a sea monster on a lake.. if I was taking a very compromised rim or tire off a tractor I would however deflate it first. I dismounted a large 16.9-24 sand tire once as the tire had a bead seperation on it. large tire.. high volume.. and letting go. now that was a bit of a danger.. I did deflate it when i saw it till I could fix it. IMHO.. more dangerous than a rim issue was that tire seperating from the bead .. already about 1/3rd let go and working around. that's a big casing... and decent volumke. wouldn't want to be right near it if it did pop.. though it's also 'comparitively' low pressure too...
i do all my own tire work usually.. have seen my fare share of tires let go when airing.. just practicing normal safety precaustions working on tires and such when mounting or dismounting or airing, etc will save ya 99% of the time.
I've aired up small high pressure ones with re0used caps and thrown an old piece of carped over them when airing.. or wrapped chain around a casing thru the rim in case of a pop off.
again.. basic safety stuff you should be doing anyway around tires and rims.
split rims? I won't work on. have had some tracors come in with them. I deflate them with a bleeder valve and walk away while they do so.. and then I put them on the scrap pile. only split rims I'll work on are bolt up split rims that have bolt together flanges.. liek the ones onmy batwing that hold aircraft tires. usually 6-8 bolts around the flange hold the rims together. them I deflate before removing bolts.. etc....
just basic safety and common sense saves you 99% of the time on most situations.
unfortunately.. common sense is exceedingly uncommon these days.. :( :(
   / Welding Up a Cracked Rim #54
This is the epitome of ANALYSIS PARALYSIS!
   / Welding Up a Cracked Rim #55
Welding a pressure that has corroded enough to leak? Ever heard tell of the military , aviation industry, state and Federal land and marine transportation laws. Then business and industry in general? How long would it take for you get fired for putting a defective pressure vessel back in service. Know anybody that is a paramedic, ER room staff, fireman or cop? Ever see the aftermath of a ruptured pressurized gas vessel. Ask them. If you were not blindly ignorant of the facts or so in love with money to cheap out on such a repair. You would Never consider maiming or killing somebody that has family and a litigation lawyer.
Ok let me understand, this.. the little campbell Hausfeld air compressor in the basement I welded up 6 years ago is going to kill some fireman or policeman? Are you saying I need to chitcan the air compressor? Let's hear from some other people on here before I do that... And what the He77 does my love of money have to do with it? Your kinda pressing my buttons here, about the "blindly ignorant, and "love of money" things. You could have worded that a little kinder, don't you think?
James K0UA
   / Welding Up a Cracked Rim #56
Can you quote us what the military, aviation, state, federal and marine agencies specifically say about welding a cracked tractor rim being welded up in a barn on private property. There's probably a lot of literature on the matter but I would like to hear it From you. Thank you
Air Compressor Tank and it wasn't me that introduced air compressor tanks into a cracked rim discussion.
   / Welding Up a Cracked Rim #57
James K0UA
How did you imagine ancompressed air tank injuring an emergency service worker? ??? Ask these emergency personal about the incidents where some jackleg repair failed and caused secondary property damage and personal injury or death.
Ever consider the tons of force pressing on the walls of that defective vessel or the amount of potential energy? Have you ever seen the destruction that a ruptured air tank causes?
   / Welding Up a Cracked Rim #58
   / Welding Up a Cracked Rim #59
James K0UA
don't let him get to you.. I've had BD on 'mute' for a while now.
   / Welding Up a Cracked Rim #60
About 3 years ago I welded a rim for a friend. He drive the tractor to the local preschool one day for show and tell. Right in the middle of his demonstration that Dam rim failed and blew the **** out of 12 little kids. Faces were permanently damaged, arms and legs sat akimbo on those little bodies. It was the worst thing that I ever saw. To this day I wish I would have heat treated that rim or used a different rod or painted it with epoxy paint or used jb weld or put a tube in it or not put a tube in it. Something. Anything. I still hear those little pukes screaming and crying. Blood everywhere. Oh the carnage that I created. If only this topic had come up on TBN back then those little chitlins would all be hopscotching and playing like normal kids, not being the disfigured freaks they are today. Then again, nothing has been accomplished by this thread. Curse you MMH for ever starting it and bringing back these awful memories.
NEW Fork Extensions (A53002)
NEW Fork...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
1993 Ford F700 Stakebody Truck (A51692)
1993 Ford F700...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
