WELL DONE!!! FER ALL TBNER'S AND BETWEEN GATOR BOY
   / WELL DONE!!! FER ALL TBNER'S AND BETWEEN GATOR BOY #91
Re: WELL DONE!!! FER ALL TBNER\'S AND BETWEEN GATOR BOY
I've done a few of them too, usually as one of the many enmass to help lower/raise. Here is a question for ya polecat:
my farm house well (been in since 70's) has steel ~4" cassing. the plastic line actually exist the SIDE of the casing about 5' down!? Never seen one like this and am not sure how you are susposed to PULL it when I can't even reach it!?
I expect I will have to dig down the outside to the HOLE in the casing and take the plastic appart there when it will need to be pulled. wires are up and over like normal. though they are all spliced up on the outside from either rats or weedeater thgough I DID have a small woodchuck appempt to live there too. had to smoke bomb and poisen him and then fix the nawed up wires. they were not damaged copper just insulation and I've been doing electrical work for a long while.)
(the vice gripps DO work but are not the best way and in many cases around here you would not pass an inspection using that crush method.) You mush use the correct crimper, (I actualy use an old pair of wire/bolt cutters which I welded up a grade 8 nut and a hunk of half round stock and crimp using that and a bolt the bolt threads into the nut and is held tight suing a lock nut.) you can adjust the deapth of crimp by raising or lowering the bolt or by under closing the bolt cutters. mine are like 18" ones. work pretty good if I do say so myself /forums/images/graemlins/smile.gif anyhow just though you may want to try and make up a set, get a cheapo pair of odd lots or harbor freight bolt cutters 18~24" and weld the nut/die parts onto the front of the jaws, so that you can still cut somethign in the back of the jaws.
Mark M
   / WELL DONE!!! FER ALL TBNER'S AND BETWEEN GATOR BOY #92
You probably have a pitless adapter in the casing. You have to use a 3/4 or 1" pipe to screw into the top of it and slide it loose.
O>>>K >>>lets make a deal here !!!u won't tell me how to splice and i wil give u my hearta nd soul on any subject u wanna talk about and ifn i don't know ...I'll b the first to say so!!!................I wonder how many people know how to run a 40 ton swage press?????for doin high line/transmission..wires that carry up to 765kv..!!!!!!!!!!!!!...first of all u have to strip the alum. back to git at the 3/4" hardened stranded core.... then u have to deal with all of the things that i could literally write 3 pages on and then u have to deal with the outer alum. corona carryin conductorand all of the little idiosycracies that it takes jist to pass inspection...not to mention the ..b4 sagging load stress!!!!!.....I will say this politely ...wire and heights r my middle name......no !!!..exclamation points...this is a fact........
I am so glad that u gave me and our guys her the leeway ....by sayin "IN MANY CASES"!!!!!....here weon tbn have the tools to git the job done...WE DON'T HAVE ...BURNDY'S....NICO..PRESSES...BLACKBURN..O...DIES..AND D...DIES..we jist have the simple tool that nay simple backyard mechanic would have...
Remember one thing my friend !!!! I am tryin to bring this down to the layman's terms....AND I QUOTE..."MY WORD EXACTLY!!AND I DO NOT EVEN HAVEOT LOOK THEM UP BCAUSE I KNOW THEM IMPLICITLY!!!!!!!!"...DO NOT SQUEEZE THE BUTT CONNECTOR 2 HARD AS U WOULD NOT WANT TO PUSH THE CODUCTOR THRU THE THE CONNECTOR..!!!!!"
i EMPHATICALLY SID NOT 2 SQUEEZE TO HARD!!!!4 THAT ON REASON...!!!!"..............and yes it will pass inspection!!!!!!
I have yet to ever have an inspector to EVER NOT PASS MY SPLICE'S !!!...that would be 800mm........transmission....down to anything in distrubution...from 4/0 down to #4,6,and even #8 solid copper...and then 1/0,....2/0...3/0....4/0...copper and allo of the aforementioned wires...including...triple ac...acsr....and all of the incongruent...wires in between...and lets not forget hendrix!!!!...spacing!!!!..and proper peeling/coring of the outer 3 layer's...how bout coax...how bout fiber!!!how bout 900 pair copper!!!!,,,,at 14#'s a foot!!!
I have been everywhere on and up and down a pole...EVERYTING THAT TRANSMIT'S POWER....EVERYTHING THAT TRANSMIT'S......TELLY...CABLE AND FIBER SPLICIN TO BOOT......transmission steel towers...up to 1000' up in the air!!...microwave towers up to 3..k'.....to telly..to fiber....(my best day was over 4 miles hung..lashed..and strapped..and with the loops included!!!!>>>)..what would u like to talk about?????..the proper layout of tools in a T40..so as to make use of yer time the most efficiently???or wouuld u rther talk bout 90' hirangers...doin hot stikkin on 115kv....how bout 160' remot cntrol terex boom crane's with yer a$$ tied to the other end of the fishin pole doin bell coonin at 200' cuz u can't reach the work????..even with yer jib extension on and the man basket fully xtended????..............
OK AND IF U R SO SPLICIN WISE???TELL ME WAHT THESE 2 TOOL'S R????
P.S...............REVERT TO PAGE SIX ON THIS STRING!!!!...DON'T EVER COME ONTO A STRING AND THINK THAT U KIN KNOW IT ALL TILL U READ IT ALL!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif...WE HER AT TBN GENERALLY DO HAVE IT COVERED ...YOU'LLL JIST HAVE TO TRUST ME ON THAT ONE !!...so kindly go back to page 6 and maybe u oughta go back to page one and read the whole thing stead of jis jumpin in..
all my bestmy new found friend and hope to see u and flea likr soon /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif.....so come on mr makea conektor krimper!!..wut r day??? /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
and by the way ???tell me what these r???
and how many kv's r these rated 4444?????
and what about these babies????and wht r the things on the right 4???? /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif ........dont worry i no dat my attchments rnt atacchhin ..will fix in d mornin!!!!
BY THE WAY !!DON'T TRY TO EXPLAIN IT !!!GIVE US A PIC......please..cuz if u have the new idea on the block i wanna c it!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
by the way...the above does not have pics because my camera died 2 days ago while tryin to download some pics!! /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
OK GUYS !!!!!!!THIS IS THE BIG DAY SO STILL HAVE ALOT OF TYPIN TODO!!!!..AS WE SPEAK !!! OUR HERO GMAN IS AT HOME DEPOT PICKIN UP HIS GEN...SO HERE GOES THE FINISHIN TOUCHES ON THE INSTALLLATION!!!
This pic is of the attachment of the pipe to the pump...sorry if this pic is a little shaky!!!....can anyone see the mistake i made here.......?????when making the wire splice i forgot to puton the 2 clamps for the 1" pump brass and the 2 clamps for the bottom torgue arrestor!!! good thing the come apart eeeeehhhhhh /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Ok !!!! now were heating !!!!!!!GENTLY !!!!THIS STUFF BURNS REALLY EASY!!! up the 1" black plastic well pipe...in order to attach it to the male ribbed brass fitting on top of the well pump after gittin it nice and warm jist slide the pipe over the nipple and calamp it down quick..the soft plastic will literally for to the serrations of the bralss nipple and harden to fit them...don't clamp down too hard with the pipe being soft....as it can literally cut the pipe..i u mess up it's ok..just cut 6" off the pipe and do it again...as i stated b4...do not scorch the pipe /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif...and be sure to put one clamp on one way and one the other so they are tightening in opposite directions /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif...tape all clamps up real weel to prevent chaping of the wire..also at yer mid line splice be sure to leave a little slack or belly to keep the wire from rubbing on the connection...tape the wire directly above and directly below any splices in the pipe...this also goes for the thrust boots....and i would liberally tape the wire under both clamps of the thrust boots too as the wire literally has to run UNDER THE CLAMPS HERE...SO TAPE THE WIRE..THEN TAPE THE WIRE TO THE PIPE WHERE THE CLAMPS TIGHTEN DOWN OVER IT...PUT ON THRUST BOOTS..TIGHTEN CLAMPS...AND THEN TAPE CLAMPS.... /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif
2019 Allmand Bros Maxi-Lite 2V 15W S/A Towable Light Tower (A52377)
2019 Allmand Bros...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
19200 (A50324)
19200 (A50324)
