Well Drilled - Results
   / Well Drilled - Results #121
The well is at the cottage, which is 2.5 hrs. North of Toronto, up in the Canadian Shield. Drop pipe is 2", and the driller told me you could never predict water flow when you drill. For example, we also had him drill at another cottage we own, about 500 yards away. There, he got 15 gallons per minute at 45 feet!
Your water source is cracks in the bedrock?
   / Well Drilled - Results #122
Water is coming in from ALL those areas, over 260 feet of water inflow, water is found 505 feet (bottom of well) up to 220 feet (Static water level). Water is constantly coming into the well casing area from ALL those levels (220-500 feet).
BTW- They will install a pump shroud/torque arrestor.
Why wouldn't the pump get the cooling it needs if it is sitting in 500 gallons of water and constantly submerged with with at all times?
Well I stand corrected on one count. I just checked and you can get a 4" shroud in 4.5" casing. But boy is that a tight fit. However, that does solve one of your problems as that will force water past the motor even though the pump is being fed from above. The tight fit of the shroud might make it tricky to pull and set the pump, but the tight fit is a good thing for cooling the motor.
With a 4" shroud on a 3.5" pump, the motor can get adequate cooling with flow as low as 1.2 GPM. Being submerged in water isn't enough to cool the motor. There has to be .5 feet per second flow past the motor. Even if the pump was set in a huge lake or a well that is 10 feet in diameter, the motor could overheat without a shroud. If there is no natural flow past the motor from the lake or big well, you can be pumping nice cool water while the water around the motor is boiling and overheating the motor. For this reason a shroud is actually more important in a large diameter well than a small diameter well. That is only if the pump is set above all perforations. If the pump is set down below any perforations, a shroud is as important as it is when installing the pump in a lake.
A 4" shroud in 4.5" casing is such a tight fit that if you drop something like a pebble the size of a pellet down the well, the pump may never come out of the well. But it will allow for proper motor cooling when setting the pump below the perforations.
However, the shroud will not help if you have cascading water. If I found water from 220' to 500', I would only perforate maybe 40' at the bottom. Then I would gravel pack the annular space between the 6.5" hole and the 4.5" casing. The water from 220' could flow down the outside of the well through the gravel and enter at the bottom perforations without cascading in the well and churning up the water.
If the water from up high is weak and just slowly runs down the side of the casing, it may not cause the churning effect. But if there is a little stream or two pouring in from up top, it can really stir up the water and make the pump lose prime. Or if you do not pump the well hard enough to draw the pumping level down below maybe 400', there should be enough depth of water to stop the churning before the water gets to the pump. If the driller has done this in that area before, he probably knows which way the water enters the well and should be able to make it work.
   / Well Drilled - Results #123
OK, so if it would really "cost less" than a VFD. Quote me an honest quote for installation of a standard NON-VFD pump motor, 480 feet of PVC drop pipe, 6 or 8 gauge wiring, stainless check valves, CSV, and two 80-gallon pressure tanks? Labor + parts
Well if you want to compare to a VFD system you would need a CSV1A/3gpm and a 44 gallon size tank. The 44 gallon tank would also be needed with the VFD system, so that is a wash. The CSV1A/3gpm would be about $200. I am guessing the larger wire, a single phase motor, and a deluxe motor control box would cost an extra $1000. Then you could deduct the price of the VFD controller, which I am guessing at $1200 to $2000. So because of the long length of large wire there probably isn't much difference in the price of the VFD and CSV system.
But the smaller wire is how they lock you into replacing the VFD controller a time or three. Sure they may warranty it if it quits in the first 5 years. But 5 years and 1 day later the cost will be all yours. And the VFD will shorten the life of the motor. So even though the up front cost will be about the same, over a 20-30 year life, the VFD system can cost many thousands of dollars more than a normal single phase system, which is exactly why people who make their living selling pumps push the VFD system.
Using a couple of 80 gallon tanks and no CSV would cost a bit more, but would probably last as long as the CSV system.
Now don't get me wrong. In spite of the extra cost in the long run, there are many advantages to a VFD system like being able to use smaller wire. It will also deliver constant pressure to the house or sprinklers, and will work with a very small tank the same as a CSV system. It is just that I believe the old saying, "when there are more than one way to accomplish the same job, the simplest way is always the best way".
   / Well Drilled - Results #124
5 GPM, 1/2 HP
With a pump that small you have to figure out if the "pressure waxes and waned" because the pump is cycling on and off while using water, or if the pressure just stays low because the pump cannot produce enough flow. If the pump is cycling on and off while showering, simply adding a CSV1A will fix that and give you strong constant pressure to the house. If the pump is not cycling, and the pressure just stays low while showering, then you need a larger pump AND a CSV to give you the volume and constant pressure needed.
I talked to the pump driller and he said that in 30+ years he has NEVER lost a pump due to a torque arrestor and/or pump shroud in a 4.5" well casing.
He also stated that the wells require the PVC casings because wells can collapse and fill in with sediments. He said the things they do in other states is not the same as here. Geology changes and what works out east doesn't work out west. The PVC casings are a safety measure to prevent collapsing of the well which would require abandoning and drilling another $8k well + $6k well pump. Costing the homeowner $14k in a lost well vs a PVC pipe casing for a few hundred dollars.
So a non-VFD setup with the two 80-gallon tanks, etc. would be around what? parts & labor $6k?
   / Well Drilled - Results #127
I fully understand how drilling a well in the SW Desert area of the country is different than it is here - I can still hear the words of the guy who drilled our well over 40 years ago when I asked him why 'that exact spot' he chose from the location where we wanted the well. "Hey, this is Florida - poke a hole anywhere and you are going to hit water," then, as he looked up towards the sky, "This is where I can stand up my truck!" The well was going in a wooded area.
   / Well Drilled - Results #128
30 years ago the VFD would have cost and extra $10,000, but I would have tried to talk you into it anyway, telling you how cool they are and how much energy they save. Which would have been a lie as I learned later that VFD's do not save energy and do not make pumps last longer. Just like cell phones and calculators, VFD's have gotten a lot cheaper over the years, but they still can't save energy or make pumps last longer.
The cost difference depends on how much your installer charges for pressure tanks and/or a VFD. He probably charges $1000-$1200 a piece for those tanks, which you can get for 500 a piece. He also probably charges $1200-$2000 for a VFD, which you can get for probably $300 from driveswharehouse.com.
But even if there is no difference in up front cost between these two systems, I guarantee you will pay 2-3 times as much over the next 20 years to keep the VFD system working. And even though VFD's do not save energy, they are still cool, as constant pressure is cool anyway you do it. :)
   / Well Drilled - Results #129
You can just put a pressure regulator after the pressure tank like I did. Been working fine for 16 years.
   / Well Drilled - Results #130
That gives you constant pressure in the house while the well pump is still cycling itself to death. You can get away with that if you don't use much water, like for irrigation. Try that with a heat pump, drip system, or just varied flow irrigation and you would have bought 4 new pumps in 16 years.
The CSV gives you the constant pressure in the house AND keeps the pump from cycling. Saving the pump from all those cycles is what the CSV was designed to do. The fact that is also gives you constant pressure in the house like a regulator is just gravy on top.
Kubota B7100 Tractor (RUNS) (A50774)
Kubota B7100...
1999 Peterbilt (A50120)
1999 Peterbilt...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A52748)
2012 NEW HOLLAND...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
2017 Ford Explorer SUV (A50324)
2017 Ford Explorer...
