wench
/ wench #41
Guess I just don't understand how a legged winch would provide and 'anchor', and not just pull the tractor rearward. Perhaps it's designed for a 'track' machine? ~Scotty
/ wench #42
I've seen both types, the ones with legs are mostly older winches. A friend of mine has one with legs, works fine for him. Personally, I'd sooner have the blade. It's likely an older Norse.
Chilly
/ wench
Is it possibly a Norse? I have an old one, a 2500, with legs. The pic attached shows a receiver carrier I use in the woods, but you can see the winch also. This never had a blade, though they were optional then. I've thought about adding a blade but I use the 2" receiver too much and the blade would limit how low it could go to catch a trailer pintle.
Jim
so far this is the closes i have seen the only difference is the legs on mine are bigger ...........thanks jimmysisson
/ wench
THANKS TOO EVERY ONE THAT HELPED ME OUT :D:D:D
/ wench
it is different:confused: but the legs have little graber grubers plats...??????...under the legs :confused:
John Deere 348 Square Baler (A65579)
John Deere 348...
2014 FORD F350 4X2 S/A DUMP TRUCK (A59914)
2014 FORD F350 4X2...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
Bush Hog 285' 3Pt Mower (A66285)
Bush Hog 285' 3Pt...
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
