What brand filters and engine oil in your kubotas?
   / What brand filters and engine oil in your kubotas? #51
I just did the 50 hour for my BIL's Kubota L3200 hydro machine.. We used all Kubota filters and fluids. He said there is not that much difference anyway in the price and he did not want to mess with trying to source filters elsewhere, and just used the Kubota oil as well as the dealer put together a package for him. All went well.
NAPA story was on a New Holland, but brand is beside the point.
I've been though a few fleet guard presentations on this stuff, fleet guard is probably the biggest OEM for tractor filters. I know they do some Kubota stuff, but not all. They do most everything for CNH. Their platform is that a car is typically under a highly variable load, averaging around 20%. A tractor is under a much heavier load without nearly as much variability. For that reason, its much easier for an aftermarket filter to preform on a car or truck than it is on a tractor, the spec does not need to be as close to what the factory intended. When cross referencing something, you simply don't know how close the filter really is to spec. You also don't know mechanical designs like will it bypass and how much, flow rates, etc. Its very possible to get a good cross referenced filter and I am sure there are good products out there, but finding the right match is really a lot more complicated than just checking if the threads fit.
good info here. makes sense to me as far as explaining the differences between vehicle and equipment filters. thank you.
I do believe that it states somewhere on NAPA website or the actual filter box that all NAPA filters are guaranteed "to meet or exceed oem manufactures specs" I will have to look for that statement again to be 100% sure. another comfort to me is that under every NAPA/WIX filter I cross referenced for my kubotas was a list of equipment that the filter could be used in, and all my equipment was listed per specific filter and use. to me this puts all the liability on NAPA/WIX if there is a failure, provided all my ducks are in a row so to say. and NAPA states they will replace or reimburse the customer if it is found their product indeed was the cause of a failure.
now I know NAPA can surely find a loop hole if they really want to, just as kubota or new Holland was trying to do in messicks above story. so any company can try to deny a claim weather it is oem or aftermarket. I have also heard/read on here (TBN) of aftermarket filter companies, such as NAPA and FRAM "making it right" for the customer after they had an equipment failure deemed to have been caused by the aftermarket filter.
on fluids. Any CJ-4 engine oil is fine. No worries there.
SUDT2 can be important to run in some machines. Gear drives and warm climates can sometimes get away without it, but here in the North East we do see performance and noise differences when your not running the intended hydraulic fluid. You'll find that echoed by many people here. At this point, there is no one doing an oil that's actually a true replacement for the trans fluid. In the newer tractors, the service interval chart shows much longer change intervals IF your using SUDT2 so the little added cost there at least has some mileage.
Mostly agree with these SUDT2 statements as well. I have heard/read many statements/stories that repeat the above statements. and I do completely agree with the longevity of the SUDT2 fluid helping offset the higher cost, so that is why I stick with the SUDT2 for now.
However, I also have real life stories of folks running many other UTF (universal tractor fluids) in their KUBOTAS and live in Pennsylvania's winter climate and have gotten along fine for years.???:confused3:
one brand I have looked at very closely is the "travelers premium tractor fluid" that tractor supply sells. cost=$45.00 per 5 gal.
cost of Kubota's SUDT2=$125.00 per 5 gal.
big difference in price. the cold *F pour points are the same specs at -42*F (I believe) so wouldn't that make the travelers brand the same as the SUDT2 as far as cold weather temp operation?
like I say, I will stick with the SUDT2 for now, but I still will keep on researching this topic.
   / What brand filters and engine oil in your kubotas? #54
My L4200GST gets Kubota filters all around, Rotella dino 15W-40 in the engine, and 10 gals of generic HD tractor hydraulic & transmission oil from Sam's in the back (10W20). Incidentally, never an issue with the transmission or hydraulics down to 10-15F (I refuse to go out when it's colder than that). Hydraulic clutch engagement is a little slow for a minute or two, then it's fine. Was $33/5gals last I bought it, but it's gone up to $43.
   / What brand filters and engine oil in your kubotas? #55
one real life experience to add to this (self serving, granted)...
we have had tractors though with non-OEM filters that collapsed because they did not pass the amount of oil necessary. In a recent case, NAPA would not pay the bill. Had that been an OEM filter, the customer would be $4500 richer as there is no where else to point fingers. Generally, OEM filters are priced inline when your comparing them to like industrial filters (fleetguard), and only a few bucks more than one an auto parts store will sell 10 minutes later to go on a mini-van. IMO... OEM filters are cheap insurance.
+1.
I work my tractors, both are ag tractors doing field work, not mowing lawns or playing wannabe farmer. I don't play, I farm. I use Kubota filters exclusively on both my large frame (M9 and 105) Kubotas period. Out in the field, they are up on the turbo's doing what they are designed to do...work.
Far as oil, Shell Rotella T5 synthetic and change intervals according to Kubota recommendations. My tractors cost big money and they have to be dependable. I don't screw around. Your oil is the cheapest thing you'll ever buy and your filters are cheap as well. Why chance it. If T5 is recommended for my Caterpillar 3406 in my Western Star it's fine for the tractors too.
If you aren't sure your oil choice is doing the job, get an oil analysis.
Don't forget your transmission and wet brakes like most people do. It needs changed at recommended intervals as well. Deviating from the SUDT or UDT, I use Chevron THF synthetic and Shell 90 weight GL5 rated gear oil in the fromt wheel assist.
My tractors are a sizeable investment in my operation. I don't skimp on consumable parts.
   / What brand filters and engine oil in your kubotas? #56
Just do not use the WIX/NAPA cross for the inline diesel filter on the RTV, BX and G series machines plus others because their cross is just a screen and not a diesel fuel filter with paper element.
This is why I do not trust their filter cross table.
Look at the applications list.
Part Details Wix 33972
So what will a 50 micron screen filter?
David Kb7uns
   / What brand filters and engine oil in your kubotas? #57
Never mind the brand of oil/filter, I just like to know where online I can buy an oil filter + 15/40 oil at a fair/good price.
I type in Kubota L3400 motor oil filter, and come up with two choices so far, Coleman Equipment, easy site, fair price on parts and the shipping charge, and S.H. cost is up front and easy to find, but it's halfway across the country from me, which is ok I guess. Then Messick's is closer, easy site to find parts, but I spent half hour trying to find S.H rates on oil/filters with no luck so I gave up, if I cant find shipping charges up front, I move on. I've been on to many websites where after finding what I want, fill in all address info, the S.H. charge ends up being more the parts.
I'll try Ebay now, and No, I don't like spending and hour or two going to the nearest Kubota dealer or anywhere else to get oil and filter on a Sat. morning if I can just click and buy from the comfort of my couch/office, during TV commercials while watching America's Ninja Warrior, and thinking, I use to be able to do that. Then wait a few day's, come home after work and the package is on the door step, now that's connivance.
   / What brand filters and engine oil in your kubotas? #58
   / What brand filters and engine oil in your kubotas? #59
The convenience of shipping is expensive.Messicks is a great place to deal with but on small orders it gets pricy for shipping.Maybe purchase enough for multiple oil changes would help.
   / What brand filters and engine oil in your kubotas? #60
I use OEM filters and SUDT2, oil is a 15W40 from oil distributor in a 55 gal drum and it is whatever is on sell at the time I need it. Sometimes is is Shell, Delo, Valvoline and I use it in everything but the car (Ford only wants 5w20 in it).
BTW- My dad owned a napa store for over 50 years in a farming community, he has seen lots of failures of equipment and vehicles, none due to putting on the correct filter and oil being in them. Most were due to incorrect filter (cross of a crossed filter) or no oil.
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A55218)
Neckover GL24-2-7K...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
