What causes flip overs?
   / What causes flip overs? #22
Bear with me, but in my mind I'm thinking that since the rear wheels aren't moving but you are giving it the gas, is the tractor actually "riding around it's own axle," so to speak? Is that why it happens so fast?
Thats correct, however it doesnt just happen like that: The friction of the rear wheels to the ground alone, arent enough to create enough moment to flip the tractor: You first must get all the tractors weight on the rear axle (front wheels off the ground) to get the grip you need to flip it, or the tires will just spin out.
This needs another factor: weight transfer. If you hook the chain above the centerline of the rear axle, you are creating leverage to pull the front axle up, which gives more grip, enough to backflip without spinning the tires.
In general, if you hook the chain at or below the centerline of the rear axle, backflip on flat ground is impossible.
If you hook it up just a little above the rear axle center line, you'll get some weight transfer, and the front end gets up a little, which in turn puts the drawbar down: So when the drawbar gets at the same height as the centerline of the rear axle, this effect is zero.
It gets dangerous when you hook up the drawbar so high, that the front end gets up way above the ground, shifting its own center of gravity closer to the rear axle.
My preferred method for heavy lugging is to use the 3pt bucket as ballast, and hook the chain to the top link A frame. It gives ballast for extra traction, and serves as a backflip limiter as well. I can control the amount of weight transfer by lowering or lifting the 3pt.
When not using the 3pt bucket, i pull from the lowest top link hole. mine has four holes, the lowest is about 6 inches above the rear axle centerline, which stops a backflip when the front wheels are less than 2 feet off the ground. this gives the most traction without getting unsafe.
   / What causes flip overs? #23
I had a neighbor just about get killed pulling from his FEL in reverse. He was on a NH, about 30 hp, and the rear wheels came up. He panicked and pushed in the clutch. It slammed to the ground so violently his foot slipped off the clutch and it went though this cycle 3 to 4 times before he could get it under control.
...So he didnt think of lowering the FEL ?? I assume he pulled in high range ?
It allways seems to be that people that dont have the operating hours (experience) to respond to the unexpected, mostly do crazy things in high range which gives them even less time to think....
   / What causes flip overs? #24
Here's another thing to be aware of, especially you guys who live in cold climate. If you leave your tractor out overnight under certain condition (muddy ground and freezing at night) and the tires freeze to the ground, you can flip the tractor over when you start up in a forward gear. You should always start out in a reverse gear under these conditions. I have heard of people actually parking their tractors with the nose to tree or a barn to make sure they don't forget and drive forward.
Yes, except you have it backwards. Driving off forward would only shove the nose of the tractor into the ground if the rear wheels are held fast and cannot turn. If you try to move first in reverse in that scenario, you could turn a tractor over backwards. The tires would be trying to rotate downward on their back side (back of the tractor) and that force could raise the front of the tractor over backwards. Nosing into a tree or barn would be the absolute WORST thing you could do if this was a concern. If anything, you'd back against something assuring that you would first drive forward if you weren't thinking about it when you got on the tractor and drove off.
*EDIT*
See post after Beppington's post.
   / What causes flip overs? #25
Pretty sure a re-think is needed here :thumbsup:
Think top-fuel dragster or funny car doing a wheelie.
Or a motorcycle popping the clutch ... When you pop the clutch, either the tire(s) will spin ... or the front pops up.
I get messed up on these things, too.
   / What causes flip overs? #26
Um, I do believe you are correct and I even demonstrated this to a friend using his R/C truck several years ago. Can I blame it on a senior moment? The friend swore the opposite and I attached the rear tires of his R/C truck to a 2X8 board with hose clamps and told him to try to back it up. Instead, he said he wasn't going to ruin his truck and floored it in forward gear. It immediately flipped on it's back so hard that it shattered the body of his R/C truck. Clearly he saw what happened. Maybe he channeled the backward information to me on the last post. :eek:
   / What causes flip overs? #27
Having owned a Farmall A that was cracked in half (before I got it) being pulled from the front end when the rears were frozen in, I highly recommend parking where a puddle won't freeze the tires to the ground.
Jim
   / What causes flip overs? #28
Jim
LOL, I agree. In high school I had a VW Beetle with the "auto stick" transmission. The temps dropped after rain turned to snow and it literally didn't have enough power to do anything. It just sat there and grunted. The only thing that got it out was the heat from the rear air cooled engine finally melted the ice enough to free it. Man, it was one powerful beast with it's single port 1500cc engine. Literally, I could sit still on ice, floor it taking off, and it wouldn't spin a tire! What a monster. There were clearly no dangers of it doing any sort of flips from this issue. LOL!
   / What causes flip overs? #29
It's not just VW's, Dargo. I froze the front tires of a 3/4 ton crew cab (2wd) into a puddle and had to get the neighbour to pull me out. The back tires just spun. Couldn't even get enough momentum to rock it.
Freezing the back tires of a tractor into the ground will cause the front end to come up when you move forward. I've never flipped one over, but I have managed a small wheelie. Scary enough to make me more careful, at any rate.
   / What causes flip overs? #30
Man, I hated that car. The clutch was vacuum operated, so if the engine wasn't running you were in permanent neutral. The only standard you couldn't push start.
FAKE (A52472)
FAKE (A52472)
2025 Swict 66in Bucket Skid Steer Attachment (A55851)
2025 Swict 66in...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2001 Acura MDX SUV (A53424)
2001 Acura MDX SUV...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
