What do you keep the thermostat at inside the house in the winter?
   / What do you keep the thermostat at inside the house in the winter? #61
Good Evening,
The house right now is 68.9 in the kitchen, 20 outside. This is the Ct home, in the Vt house we use propane and have a wood stove in the family room, its very difficult to keep that room below 75 no matter how cold it gets ! I insulated the heck out of that addition when I built it, and it heats up really quick.
CADplans has it right, that humidity level really makes a difference on the feel !
   / What do you keep the thermostat at inside the house in the winter? #62
Interesting - heat pumps....... if its too cold for them up in the NE and too hot down south -- where do they work.
Humidity plays a big part in how comfortable it is in my house. Its 68F inside but it feels a little nippy because the humidity is only 23%. I've tried increasing the humidity but its a PITA. To get the humidity up to 30-35% I get sweating on the windows. I've just learned to put on a sweat shirt and remember I live in a semi-arid area.
<snip>.
It's not too hot down south for heat pumps.
   / What do you keep the thermostat at inside the house in the winter? #64
I keep my house at 72-73 year round.
   / What do you keep the thermostat at inside the house in the winter? #65
I would think say it's too cold for the up north. Just have to factor everything in
Modern heatpump are still effective down to 10 F and below. Where they still will make more BTUs of heat per watt of power consumed than resistance heat. Meaning they are still more efficient than than baseboards or electric furnaces.
The issue is below that, you still need something else for backup.
With propane and gas being cheap, if your north, you may choose to not get a heatpump. But on those milder days when it's 30-40 outside....Heatpump is about as efficient as it gets.
   / What do you keep the thermostat at inside the house in the winter? #67
The humidity is a major factor.
If the humidity is high, at 72 degrees you will be wearing a bathing suit.
If the humidity is low,, at 72 degrees, you will be wearing a sweatshirt,,,
Time to go boil a pot of water!! :thumbsup:
I have suspected humidity. My primary humidity detector is a door that sticks when the humidity is high. I should try something more scientific. The other possibility I have considered is a psychosomatic cause...
   / What do you keep the thermostat at inside the house in the winter? #68
I also have one of those doors that only shuts easily 3 months out of the year. We keep the house humidity at about 38-40% in the winter. If temps get into the low teens to single digits we have to lower it a bit to prevent condensation on the windows. Make a huge difference in how warm the air feels.
   / What do you keep the thermostat at inside the house in the winter? #69
we use the masonry fireplace as much as we can right now 70 in half the house
   / What do you keep the thermostat at inside the house in the winter? #70
We also use a woodstove as our primary heat source, with a forced hot air furnace for backup, spring/fall nights where it's not really cold enough to light the stove or just to quickly warm up the house on a cold morning. Usually the thermostat is kept all the way down, turn it up only when we need it. Only downside is that the bathroom is diagonally opposite from where the stove is, so it tends to stay cool. Doesn't really bother me, wife uses a space heater in there.
forced hot air is terrible, about the worst possible way to heat a home if comfort is concerned.
Curiously why do you say that? Certainly for our needs it's probably the best way...turn it on and within 10 min or so the house is comfortable. Try that with radiators.
First couple winters we were here we didn't have the woodstove yet and used the furnace as our sole means of heat. Downstairs stayed nice & warm, upstairs not so much.
Our house is 1830s-vintage, but is reasonably tight and insulated as old houses gp.
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
Informational Lot - Financing (A56438)
Informational Lot...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
LIGHT TOWER (A56857)
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
