What is it? Found along the railroad tracks.
   / What is it? Found along the railroad tracks.
I should say that it isn't lost. It's mounted in the ground next to the tracks. If it had just been laying there I would have picked it up and opened it with a master key I have in my shed.
Is this near a road crossing etc...?
Its about 50 yards from a trestle bridge that goes over a two lane road.
   / What is it? Found along the railroad tracks. #23
Well. I believe we have the answer with the trackside lubricator. I have learned something today. But I did mention I thought it might be some sort of pump.
   / What is it? Found along the railroad tracks. #24
The square box is the holding tank for the curve grease. The 4th picture is of the actuating plunger, the round peg is on an oval lever. As the wheel tread (flat part of wheel) of each wheel pushes down on the peg, it in turn, turns the shaft. Pumping out a little grease each time. As the wheel flange goes by the knife edge applicator bar,(missing in the pictures) the flange picks up the grease and deposits it on down the rail.
They were usually put in ahead of curves to grease the high rail as the axles were solid. The speed and going around the curve forces the wheels up against the high rail. The wheel on the high side has to turn faster than the low rail, thus wearing the rail down. Wearing the rail out and over the years, the rail is replaced with newer,longer and heavier rail.
The last rail that I worked with was 141#, that was 141# every three feet.
The last gang I was on was a material distribution gang. Distributed spikes,plates and anchors.
Usually started in Kansas,on to Missouri, Illinois,Wisconsin,Minnesota and Iowa.
This past year we distributed material in Colorado a month before the weather really got bad.
Having worked section and different gangs across Iowa for the past 40 years, 23 on the ChicagoNorthwestern and
17 on the Union Pacific.
Finally had enough,plus a heart attack, had a triple by-pass. Retired on August 12,2013
T.J.
T.J.
This is located on a short straight section between curves so it would make sense that north & south bound trains would need it where it is. Thanks. A mystery solved (a mystery to me anyway)!!!:thumbsup:
It definitely looks like it doesn't work right now due to hoses being torn up. Lately I've noticed that I'm hearing squealing noises from the trains. I wonder if that's why.
Congrats on the retirement. It sounds like you deserve to take it easy.
   / What is it? Found along the railroad tracks. #27
How can that be......does a spring driven locomotive run in the fall.........? I think not my friend...... I think not!
To allow year round operation it winds up a rubber band instead.
   / What is it? Found along the railroad tracks. #28
Thanks for the pictures and information. It was interesting!:thumbsup:
   / What is it? Found along the railroad tracks. #29
Here is a patent drawing of the lubricator with a drive shaft.
Full diagram:
http://patentimages.storage.googleapis.com/pages/US2486600-0.png
Patent:
Patent US2486600 - Rail lubricator - Google Patents
Secured to the other side of rail is plunger mechanism,... including a plunger adapted to be depressed by the treads of wheels. The plunger mechanism operates through suitable clutch mechanism, ... to drive uni-directionally a flexible shaft extending to a lubricant tank set in the ground alongside the track and filled with lubricant ... The flexible shaft drives a vertical shaft in the tank which in turn drives a series of gear pumps...
Bruce
Winner winner, chicken dinner!
   / What is it? Found along the railroad tracks. #30
Wrong all the way. It is a pellet feeder for the hamster in the wheel. The wheel drives the winder.
Harry K
2020 ANTHEM 64T DAY CAB (A54607)
2020 ANTHEM 64T...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
Peterbilt 377 Semi-Truck (A55218)
Peterbilt 377...
2016 Ram 5500 Enclosed Service Truck (A52377)
2016 Ram 5500...
(APPROX 32) 6' X 12' HEAVY CHAIN LINK SITE PANELS (A54757)
(APPROX 32) 6' X...
