What is it? Found along the railroad tracks.
   / What is it? Found along the railroad tracks. #11
   / What is it? Found along the railroad tracks. #12
Is this near a road crossing etc...?
   / What is it? Found along the railroad tracks. #13
That is a strillium enuffrcaitor. It's obsolete. They were replaced with new technololgy. The new device is called a .......
   / What is it? Found along the railroad tracks. #14
Where do you get these crazy notions?
Actually, I'm dead certain it's a winder for a spring-driven locomotive.
   / What is it? Found along the railroad tracks. #15
Usually there is a curve and the inside of the rail needs grease applied to lesson the "binding" effect of the the wheels trying to push against the rail.
As the wheels go over it and releases a small amount of grease to the wheel which spreads it out as it turns.
There was probably a small tank there also which contained the grease but due to cutbacks and neglect they usually either run dry or break
   / What is it? Found along the railroad tracks. #16
carbolic conspazmorgate?
   / What is it? Found along the railroad tracks. #17
How can that be......does a spring driven locomotive run in the fall.........? I think not my friend...... I think not!
   / What is it? Found along the railroad tracks. #18
Okay, you got me. At least I used real words. :laughing:
Quote Originally Posted by JPRambo View Post
Have you cut the lock to look inside yet?
I think the RR guys frown on that.
When I was 18 I might have done that. I'm not THAT curious anymore.
I prefer to ask questions on here.
   / What is it? Found along the railroad tracks. #20
Here is a patent drawing of the lubricator with a drive shaft.
Full diagram:
http://patentimages.storage.googleapis.com/pages/US2486600-0.png
Patent:
Patent US2486600 - Rail lubricator - Google Patents
Secured to the other side of rail is plunger mechanism,... including a plunger adapted to be depressed by the treads of wheels. The plunger mechanism operates through suitable clutch mechanism, ... to drive uni-directionally a flexible shaft extending to a lubricant tank set in the ground alongside the track and filled with lubricant ... The flexible shaft drives a vertical shaft in the tank which in turn drives a series of gear pumps...
Bruce
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
NEW 24ft Feed Bunk Wagon (A55218)
NEW 24ft Feed Bunk...
2018 Chevrolet Malibu Sedan (A53424)
2018 Chevrolet...
1674 (A54756)
1674 (A54756)
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2018 Atlas Copco Pas200HF Diesel Dewatering Pump (A52377)
2018 Atlas Copco...
