What is it? Found along the railroad tracks.
   / What is it? Found along the railroad tracks. #1
Daver1963
Platinum Member
Idlewild, Tn
Kubota L2800DT w/LA524 FEL, Cub Cadet XT1
We have a railroad track about 200 yards from the house. I was exploring today and found this alongside the track. It looks like a PTO shaft going into a box. It looks like at one time there were hoses that came out up to a track junction and might have greased it in some way.
I don't know. Any former or current railroad men out there?
20131119_163904.jpg 20131119_163939.jpg 20131119_163946.jpg 20131119_164116.jpg
   / What is it? Found along the railroad tracks. #2
Maybe some sort of pump to pump out a storage tank? or something.. Just a WAG, I don't have a clue.:)
   / What is it? Found along the railroad tracks. #3
Have you cut the lock to look inside yet?
   / What is it? Found along the railroad tracks. #5
How did you know it was lost? Perhaps it was being stored there (I am guessing it was on RR property). Maybe I'll come by your place and have a look around to see what I can "find". Seems a quick call to the RR is in order..
   / What is it? Found along the railroad tracks. #6
Total guess, but maybe part of some kind of switch? Lock looks new, so must be something of current value.
   / What is it? Found along the railroad tracks. #7
I am pretty sure he didn't do anything with it. He just saw it and was curious to what it is or was.
   / What is it? Found along the railroad tracks. #9
Looks like junk to me. I have seen car after car piled high with all types and kinds of junk while setting at a train crossing waiting for a train to go by. Probably fell off a train car transporting junk. Would be interesting to see what is in the locked box with a PTO going into it.
   / What is it? Found along the railroad tracks. #10
I think it is something that was installed there for a purpose, but maybe hasn't been used for quite a while. It could be out-moded by newer equipment.
Trains have air lines, maybe the hoses carried air pressure.
   / What is it? Found along the railroad tracks. #11
   / What is it? Found along the railroad tracks. #12
Is this near a road crossing etc...?
   / What is it? Found along the railroad tracks. #13
That is a strillium enuffrcaitor. It's obsolete. They were replaced with new technololgy. The new device is called a .......
   / What is it? Found along the railroad tracks. #14
Where do you get these crazy notions?
Actually, I'm dead certain it's a winder for a spring-driven locomotive.
   / What is it? Found along the railroad tracks. #15
Usually there is a curve and the inside of the rail needs grease applied to lesson the "binding" effect of the the wheels trying to push against the rail.
As the wheels go over it and releases a small amount of grease to the wheel which spreads it out as it turns.
There was probably a small tank there also which contained the grease but due to cutbacks and neglect they usually either run dry or break
   / What is it? Found along the railroad tracks. #16
carbolic conspazmorgate?
   / What is it? Found along the railroad tracks. #17
How can that be......does a spring driven locomotive run in the fall.........? I think not my friend...... I think not!
   / What is it? Found along the railroad tracks. #18
Okay, you got me. At least I used real words. :laughing:
Quote Originally Posted by JPRambo View Post
I think the RR guys frown on that.
When I was 18 I might have done that. I'm not THAT curious anymore.
I prefer to ask questions on here.
   / What is it? Found along the railroad tracks. #20
Here is a patent drawing of the lubricator with a drive shaft.
Full diagram:
http://patentimages.storage.googleapis.com/pages/US2486600-0.png
Patent:
Patent US2486600 - Rail lubricator - Google Patents
Secured to the other side of rail is plunger mechanism,... including a plunger adapted to be depressed by the treads of wheels. The plunger mechanism operates through suitable clutch mechanism, ... to drive uni-directionally a flexible shaft extending to a lubricant tank set in the ground alongside the track and filled with lubricant ... The flexible shaft drives a vertical shaft in the tank which in turn drives a series of gear pumps...
Bruce
FUEL CELL (A58214)
FUEL CELL (A58214)
2004 JOHN DEERE 310G BACKHOE (A60429)
2004 JOHN DEERE...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2020 Deere 50G (A53317)
2020 Deere 50G...
Sterling 9500 (A61306)
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
