What is it? Found along the railroad tracks.
   / What is it? Found along the railroad tracks. #11
   / What is it? Found along the railroad tracks. #12
Is this near a road crossing etc...?
   / What is it? Found along the railroad tracks. #13
That is a strillium enuffrcaitor. It's obsolete. They were replaced with new technololgy. The new device is called a .......
   / What is it? Found along the railroad tracks. #14
Where do you get these crazy notions?
Actually, I'm dead certain it's a winder for a spring-driven locomotive.
   / What is it? Found along the railroad tracks. #15
Usually there is a curve and the inside of the rail needs grease applied to lesson the "binding" effect of the the wheels trying to push against the rail.
As the wheels go over it and releases a small amount of grease to the wheel which spreads it out as it turns.
There was probably a small tank there also which contained the grease but due to cutbacks and neglect they usually either run dry or break
   / What is it? Found along the railroad tracks. #16
carbolic conspazmorgate?
   / What is it? Found along the railroad tracks. #17
How can that be......does a spring driven locomotive run in the fall.........? I think not my friend...... I think not!
   / What is it? Found along the railroad tracks. #18
Okay, you got me. At least I used real words. :laughing:
Quote Originally Posted by JPRambo View Post
Have you cut the lock to look inside yet?
I think the RR guys frown on that.
When I was 18 I might have done that. I'm not THAT curious anymore.
I prefer to ask questions on here.
   / What is it? Found along the railroad tracks. #20
Here is a patent drawing of the lubricator with a drive shaft.
Full diagram:
http://patentimages.storage.googleapis.com/pages/US2486600-0.png
Patent:
Patent US2486600 - Rail lubricator - Google Patents
Secured to the other side of rail is plunger mechanism,... including a plunger adapted to be depressed by the treads of wheels. The plunger mechanism operates through suitable clutch mechanism, ... to drive uni-directionally a flexible shaft extending to a lubricant tank set in the ground alongside the track and filled with lubricant ... The flexible shaft drives a vertical shaft in the tank which in turn drives a series of gear pumps...
Bruce
2017 MACK CHU613 FLAT TOP SLEEPER (A54607)
2017 MACK CHU613...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55302)
2020 New Holland...
Ford Pickup NR (A50323)
Ford Pickup NR...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2007 CHEVROLET SILVERADO TRUCK (A54756)
2007 CHEVROLET...
