What is the best hand rake for this application?
   / What is the best hand rake for this application? #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I have need to rake the sides of about 500 yards of road to remove rocks so that I can mow without ruining my lawn mower blades. The rocks range from about 1/2" to 3" diameter. I have been using a traditional heavy rake for the job and its not really working out. Is there a rake that would be ideal for this application? thanks
   / What is the best hand rake for this application? #2
Something like this?
Rock Picker
1/2" is a pretty small I presume you could do quite well with a garden rake, but you may have problems with the smaller rocks.
Perhaps a fine tooth pitchfork would be better.
I could imagine building a small rock picker to tow behind an ATV or riding mower. It wouldn't have to be too complex, just relatively fine pitchfork teeth to snag the rocks.
   / What is the best hand rake for this application? #3
I hand rake but I only rake 800 feet. I have to clean up after the county goes by with their graders. Sometimes I rake more that 800 feet. Depends on how messy they are as I actually mow a 1/4 mile or one way so on both sides. Problem is traffic pops stones off the road and in to the grass. I toss rocks back when walking the dogs.
   / What is the best hand rake for this application? #4
Any chance you can raise your mower height ? Hand pick the biggest ones and throw them back onto the driveway.
That,s a long driveway. Do you have any children or grandchildren ? Have a contest, and see who can pick the most gravel.
   / What is the best hand rake for this application? #5
I just envy your nice flat road. I bush hog along the more open parts of my mile-long gravel drive, and don't worry about the rocks, just the stumps. My road is not flat. But in working grassy areas around the house, I find that stones continually work their way to the surface, so rock removal is a never-ending chore.
   / What is the best hand rake for this application? #6
What are you mowing with? Have you considered one of those walk behind string mowers?
   / What is the best hand rake for this application? #8
That's what I was going to recommend. :)
   / What is the best hand rake for this application? #9
What about a blade? If you set it an a long angle and adjust its engagement, it should scrape these rocks back onto the driveway or push them into the ground to where they will not be a problem for mower blades.
   / What is the best hand rake for this application? #10
could you rent a rock hound for the dayhttp://www.wikco.com/rhrake.html I used one when I was doing landscape work and the owner had built a house in the middle of an old shale pit. :( not fun but the rock hound help make things very easy.
Zero Turn Mower (A59231)
Zero Turn Mower...
2015 Toro Z Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2015 Toro Z Master...
2011 Toro Workman HD Utility Cart (A59228)
2011 Toro Workman...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2014 Ford F-150...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
BOMAG MPH100R SOIL STABILIZER/RECYCLER (A60429)
BOMAG MPH100R SOIL...
