What is the best hand rake for this application?
   / What is the best hand rake for this application? #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I have need to rake the sides of about 500 yards of road to remove rocks so that I can mow without ruining my lawn mower blades. The rocks range from about 1/2" to 3" diameter. I have been using a traditional heavy rake for the job and its not really working out. Is there a rake that would be ideal for this application? thanks
   / What is the best hand rake for this application? #2
Something like this?
Rock Picker
1/2" is a pretty small I presume you could do quite well with a garden rake, but you may have problems with the smaller rocks.
Perhaps a fine tooth pitchfork would be better.
I could imagine building a small rock picker to tow behind an ATV or riding mower. It wouldn't have to be too complex, just relatively fine pitchfork teeth to snag the rocks.
   / What is the best hand rake for this application? #3
I hand rake but I only rake 800 feet. I have to clean up after the county goes by with their graders. Sometimes I rake more that 800 feet. Depends on how messy they are as I actually mow a 1/4 mile or one way so on both sides. Problem is traffic pops stones off the road and in to the grass. I toss rocks back when walking the dogs.
   / What is the best hand rake for this application? #4
Any chance you can raise your mower height ? Hand pick the biggest ones and throw them back onto the driveway.
That,s a long driveway. Do you have any children or grandchildren ? Have a contest, and see who can pick the most gravel.
   / What is the best hand rake for this application? #5
I just envy your nice flat road. I bush hog along the more open parts of my mile-long gravel drive, and don't worry about the rocks, just the stumps. My road is not flat. But in working grassy areas around the house, I find that stones continually work their way to the surface, so rock removal is a never-ending chore.
   / What is the best hand rake for this application? #6
What are you mowing with? Have you considered one of those walk behind string mowers?
   / What is the best hand rake for this application? #8
That's what I was going to recommend. :)
   / What is the best hand rake for this application? #9
What about a blade? If you set it an a long angle and adjust its engagement, it should scrape these rocks back onto the driveway or push them into the ground to where they will not be a problem for mower blades.
   / What is the best hand rake for this application? #10
could you rent a rock hound for the dayhttp://www.wikco.com/rhrake.html I used one when I was doing landscape work and the owner had built a house in the middle of an old shale pit. :( not fun but the rock hound help make things very easy.
2006 KOMATSU PC228USLC-3 EXCAVATOR (A60429)
2006 KOMATSU...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2017 KALMAR OTTAWA T2 4X2 SPOT TRUCK (A60430)
2017 KALMAR OTTAWA...
