What material does a weld not stick to?
   / What material does a weld not stick to? #11
Copper plate for backing then tack weld it alternating the locations to keep the angle straight. It is going to be a challenge to keep it straight. Bolting the other angle to the one you are welding might help a bit to keep the welds from drawing too much but you still need to weld opposite side from the bend as the previous weld cools it is going to contract and pull the angle.
Shield Arc might can explain it better.
   / What material does a weld not stick to? #12
Oh I don't have the words to explain how to do it. I can show you how tho.:D
Angle iron, as with square tube is easy to bring back straight after welding.
   / What material does a weld not stick to? #13
Copper works fine, unless you are welding copper. :thumbsup:
John Deere 6300 (A60462)
John Deere 6300...
Bobcat MT85 (A60462)
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
Nissan Forklift (A55973)
Nissan Forklift...
