What material does a weld not stick to?
   / What material does a weld not stick to? #11
Copper plate for backing then tack weld it alternating the locations to keep the angle straight. It is going to be a challenge to keep it straight. Bolting the other angle to the one you are welding might help a bit to keep the welds from drawing too much but you still need to weld opposite side from the bend as the previous weld cools it is going to contract and pull the angle.
Shield Arc might can explain it better.
   / What material does a weld not stick to? #12
Oh I don't have the words to explain how to do it. I can show you how tho.:D
Angle iron, as with square tube is easy to bring back straight after welding.
   / What material does a weld not stick to? #13
Copper works fine, unless you are welding copper. :thumbsup:
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2014 International Maxxforce DT (A53317)
2014 International...
