What to do with pine trees I'm cutting.
   / What to do with pine trees I'm cutting. #1
Spek
I am cutting down some pine trees on my land while clearing a home site and drive. These are 8-24 inches diameter. I don't have enough to get a paper wood truck in or pay to take to mill... Is there anything that can be done with these pine trees. Everyone is telling me just burn them, but it seems like such a waste....IDEAS...pictures of you uses?
ooops I think this is wrong forum, but would still appreciate help.
   / What to do with pine trees I'm cutting. #3
Don't know your area, but here in East Texas, where I am, pines are like weeds. They grow everywhere and if you don't mow on a regular basis, pines will take over a field in a few years.
I've tried selling them and gave some away. It's always a hassle because nobody wants them. There's just too many out there and they are not worth very much.
You might try posting an add in your local classifieds, but don't expect to sell them. Just giving them away will require work on your part. If you are willing to put in the extra effort, you can go that route.
Eddie
Eddie
yeah, selling them is out. I was thinking of stripping bark and using them somehow. I know with them green, and not treated they wont last as fencing......but figured it might work for something on the earlier homesteads before everything was treated and milled.
   / What to do with pine trees I'm cutting. #5
Got a saw mill around you? Have them cut into any lumber you think you may need ...
   / What to do with pine trees I'm cutting. #6
   / What to do with pine trees I'm cutting. #7
there are lots of chainsaw milling attachments out there that would let you cut the logs into timbers for above ground applications, such at sheds, barn, etc... if you don't have access to a band saw mill. Depending on where you are, there may even be someone here on TBN who would be willing to help out - or even just take some of the logs off your hands.
   / What to do with pine trees I'm cutting. #8
Around here any 8 to 24 inch pines would be snatched up by a friend with a mill he' ll even bing a tractor to skid them and his side loader. He has a band mill and does everything from house and barn limber to beams an flooring blanks.
   / What to do with pine trees I'm cutting. #9
What kind of pine? Where are you located? Most pine trees make good firewood. Got a wood stove in your shop?
   / What to do with pine trees I'm cutting. #10
Spek,
As was already mentioned, get someone with a portable bandsaw mill to cut those trees into useable stuff for you.
I paid 19 cents a board foot for a guy to come out and make some 2 X 6's, 2 X 4's, and about 1,000 bf of 1 X stuff for me out of some white pine we had logged.
After letting it air dry for about 90 days, I was able to frame a small building and my shop, and also cover 3 sides of the shop with it.
Good luck!
   / What to do with pine trees I'm cutting. #11
Spek,
A portable sawmill is your best bet. You won't have to haul the logs, and you can end up with a fair amount of lumber. You can locate one by checking the following sites:
http://www.woodweb.com
Check the "Sawing and Drying Directory"
http://www.forestryforum.com
On the opening page, in the upper right corner, click on "Find a Forester-Sawmill"
You can also contact the Woodmizer company and they can tell you of sawyers in your area.
Measure your logs at the small end, underneath the bark. Less than 12-14 inches, use for firewood, or posts (6x6, 8x8, etc.). Have your logs cut to standard lengths (8', 10', 12', etc; plus 4"-12" for "trim") and sorted by length. Keep the logs off of the ground as much as possible (sand and dirt dulls the sawblades, and some sawyers will charge extra for this). I don't know where you are, but you may want to mill your logs into lumber before the end of spring as you may get borers that will lay their eggs in the bark of softwoods, as well as blue stain in the wood from high humidity.
By all means, though, make use of that lumber and you will have something (plank flooring, barn siding, fencing, etc.) that you will be able to enjoy and be proud of for years to come.
I have an information package that I send to my customers with more details of the process. If you want, send me an e-mail and I will send you the package.
Good Luck!
Marty Q
Q-Saw.com (in Progress)
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
John Deere 6195R (A60462)
John Deere 6195R...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
