What to do with pine trees I'm cutting.
   / What to do with pine trees I'm cutting. #1
Spek
I am cutting down some pine trees on my land while clearing a home site and drive. These are 8-24 inches diameter. I don't have enough to get a paper wood truck in or pay to take to mill... Is there anything that can be done with these pine trees. Everyone is telling me just burn them, but it seems like such a waste....IDEAS...pictures of you uses?
ooops I think this is wrong forum, but would still appreciate help.
   / What to do with pine trees I'm cutting. #3
Don't know your area, but here in East Texas, where I am, pines are like weeds. They grow everywhere and if you don't mow on a regular basis, pines will take over a field in a few years.
I've tried selling them and gave some away. It's always a hassle because nobody wants them. There's just too many out there and they are not worth very much.
You might try posting an add in your local classifieds, but don't expect to sell them. Just giving them away will require work on your part. If you are willing to put in the extra effort, you can go that route.
Eddie
Eddie
yeah, selling them is out. I was thinking of stripping bark and using them somehow. I know with them green, and not treated they wont last as fencing......but figured it might work for something on the earlier homesteads before everything was treated and milled.
   / What to do with pine trees I'm cutting. #5
Got a saw mill around you? Have them cut into any lumber you think you may need ...
   / What to do with pine trees I'm cutting. #6
   / What to do with pine trees I'm cutting. #7
there are lots of chainsaw milling attachments out there that would let you cut the logs into timbers for above ground applications, such at sheds, barn, etc... if you don't have access to a band saw mill. Depending on where you are, there may even be someone here on TBN who would be willing to help out - or even just take some of the logs off your hands.
   / What to do with pine trees I'm cutting. #8
Around here any 8 to 24 inch pines would be snatched up by a friend with a mill he' ll even bing a tractor to skid them and his side loader. He has a band mill and does everything from house and barn limber to beams an flooring blanks.
   / What to do with pine trees I'm cutting. #9
What kind of pine? Where are you located? Most pine trees make good firewood. Got a wood stove in your shop?
   / What to do with pine trees I'm cutting. #10
Spek,
As was already mentioned, get someone with a portable bandsaw mill to cut those trees into useable stuff for you.
I paid 19 cents a board foot for a guy to come out and make some 2 X 6's, 2 X 4's, and about 1,000 bf of 1 X stuff for me out of some white pine we had logged.
After letting it air dry for about 90 days, I was able to frame a small building and my shop, and also cover 3 sides of the shop with it.
Good luck!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
