What tools for a narrow path?
   / What tools for a narrow path? #11
/forums/images/graemlins/mad.gif Not only did SPYKER beat me to the post button...he gave a much better description /forums/images/graemlins/wink.gif
Sam
   / What tools for a narrow path? #12
The rear scoop is designed to be pulled forward for digging. You should be able to maintain a constant depth of cut after setting the toplink and position control.
Switch it around to back into loose piles of gravel, dirt, manure, etc. I don't have one, but it seems like it would work great as a carry-all implement, also.
   / What tools for a narrow path? #13
I'm aware that prices vary regionally on a lot of things, but I paid $125 for mine new from the MF dealer here. It's not MF brand (not branded, just red). Reversible and pull a rope to dump. A hydraulic top link is very helpful to get the correct starting angle, and then level off at the desired cutting depth.
I was looking for something to transport loose dirt several hundred yards when I bought mine, as the box blade wasn't very efficient for that. While shopping at the MF dealer I saw the 1455v that I bought a couple of weeks later. Since getting the loader I haven't used the dirt scoop very much, but it's still around for "special" needs similar to this. Our land is flat (western edge of LA delta) but occasionally I find a need for a shallow ditch to move surface standing water.
I also agree with other posts regarding the sod cutter. If price is no object that might be the way to go.
CATERPILLAR PM622 COLD PLANER (A60429)
CATERPILLAR PM622...
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
2022 CATERPILLAR 289D3 SKID STEER (A60429)
2022 CATERPILLAR...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case IH 496 Disk (A59814)
Case IH 496 Disk...
