What's your diesel engine oil?
   / What's your diesel engine oil? #41
Sully2 said:
Its being whispered about....that you have a Harbor Freight 90 amp-115V MIG setup on order. Any truth to that?.....
ROTF LMAO!
Harbor Freight?? Are you kidding me............Just call China and ask them on their CS line.
   / What's your diesel engine oil? #42
This explains so much! I could not figure out why Dargo had so many problems with Possums. Now I know. He is buying his Possum Beating Bats (PBBs) at HF and they just can't Get R Done. If he bought PBBs from Snap On or at least Craftsman he might be able to tangle with the Fearsome Possums! And Win! :eek::D
Later,
Dan
   / What's your diesel engine oil? #43
Tractors-Cenex 15W-40, all year long
3208 Cat- Cenex 15W-40, all year long
NTC 290 & 300- Walmart 15W-40 (Hey, when a oil change takes 6 gallons......it's seasonal use only...)
Doesn't get cold enough to worry about using anything else.
I think I'm seeing an understandable trend here. Those living in moderate areas don't run the synthetics as much. Those, like myself, living ing colder climates use the synthetics for cold starting.
   / What's your diesel engine oil? #45
And I only run synthetic in the winter just for cold weather starting. In the summer I go back to dino oil.
Bob
   / What's your diesel engine oil? #46
I had been running the Rotella Syn and just switched over to Amsoil HD 15-40 Diesel & Marine Oil. I tried a little experiment with the oil placing a quart in the freezer overnight to observe it's flow rate in the cold and I was pleasantly surprised. It poured very well compared to regular dino 15-40. I went with this oil since I'll put 200+/- hrs a year on the tractor and I'll just change it once a year. I figure I'll have good cold start up lubrication and also be protected on those July afternoons with the shredder.
John
   / What's your diesel engine oil? #47
I'm using Cenex Maxtron synthetic blend fluids in my Branson 4020. Hydraulic fluid has outstanding cold flow characteristics, (it's a real pretty blue which is easy to see in the sight glass). For motor oil I use the 5w40 in winter and 15w40 in summer and the Maxtron grease w/moly seems to work as good as anything else I've tried.
I bought about a 3 yr. supply of their product last spring just for the tractor.
snoboy
   / What's your diesel engine oil? #48
If I had to worry about cold starts and had access to electricity where I parked my equipment I'd get a block heater.
   / What's your diesel engine oil? #49
Oil pan heater. They are worried about lubrication, the flow of the oil to the engine when cold. Most when there is a coolent heater, the heat stays in the engine for starting.... but the oil pan, at times, stays cold, takes that little 'extra' to get to all the parts.
   / What's your diesel engine oil? #50
if you just heat the oil, the oil might flow easier but the engine still wont be all that EZ to start due to the cold cylinders . if you heat the water jacket it warms the whole engine block. the rest takes care of itself.
either way, anything is better than nothing. mostly depends on climate.
2021 CATERPILLAR CB2.7 DBL DRUM ROLLER (A52705)
2021 CATERPILLAR...
Adams 6Ton Hydraulic Lime Spreader (A55301)
Adams 6Ton...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
2008 JCB 520-40 TELESCOPIC FORKLIFT (A51406)
2008 JCB 520-40...
Duetz Power Unit (A50120)
Duetz Power Unit...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A52377)
2019 Allmand...
