Where to find extension springs?
   / Where to find extension springs? #1
mediocrates67
Perham, MN
Century 3045
So I found out my Century 3045 seat assembly is missing a spring on one side (which explains why it hasn't been the most comfortable ride). I'm awaiting a quote from Branson on an entirely new seat assembly, but that sounds expensive. Of course no one can get just the spring that I need and I live in a small town. I got an online quote of $235 for this stupid seat spring from a custom spring manufacturer, but obviously I'm not doing that.
Does anyone have any suggestions on where to find an extension spring?
8" total length. 4" coil length. 1.25" outside diameter. 0.250" wire thickness. opposite hook ends.
Thanks in advance!
   / Where to find extension springs? #2
mcmaster.com
Good luck.
   / Where to find extension springs? #3
+1 on McMaster-Carr. The spring rate in lbs/inch is an important number. McMaster 9654k391 looks close to your dimensions and it's rate is 87.66lb/in. Buy 2 new springs to get a matched set. McMaster can also make custom springs. McMaster-Carr.
Hey, thanks guys! I just ordered a couple of those. Not sure how strong they'll be, but should be good enough. At least for $18, it isn't a big deal if they're not perfect.
Rotadairon RD145 Pull-Behind Rotary Tiller Tractor Attachment (A59228)
Rotadairon RD145...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
CATERPILLAR 308E2 CR EXCAVATOR (A60429)
CATERPILLAR 308E2...
case 370 glass door never installed (A56438)
case 370 glass...
MASSAGE CHAIR (A58214)
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
