Which is more common: 1/2" or 3/8" couplers?
   / Which is more common: 1/2" or 3/8" couplers? #41
Yep is a jic. What female end works with that. I can't seem to find any locally.
   / Which is more common: 1/2" or 3/8" couplers? #42
None most likely, you'll probably need a JIC to NPT adapter.
   / Which is more common: 1/2" or 3/8" couplers? #43
Are you looking for a coupler to thread on there? If so, you will need adapters as kenny mentioned. That Tee is made to have a hose go on there. And JIC female hose ends are probably the most common end you will find. Usually the cheapest too.
If you want to thread on the couplers directly....you need an adapter like this 6505 | Male Pipe x JIC 37° Swivel Nut
   / Which is more common: 1/2" or 3/8" couplers? #44
Those are ISO 7241 "B" couplers not "AG"
The ones at TSC are probably the "A" or "AG" style and if so are not compatible.
I agree, notice the front end of the male fitting is longer on "B" couplers sets.
1995 PETERBILT 377 TRI  AXLE DUMP TRUCK (A54607)
1995 PETERBILT 377...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A54814)
2007 Ford E-450...
BELSHE DT-235 (A53843)
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A54607)
2023 MAXEY G8X...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
