Who builds Cabela's brand tractors?
   / Who builds Cabela's brand tractors? #31
I can't say that all of them are but I could comfortably say 90% of them. They are industrial engines used in a lot of different types of equipment. In the 40 horse range they would be used in small skidsteers and mini excavators. Water pumps generators mobile air compressors. Its nothing to wory about. Really unless you are looking to get more than 7000 hours out of your machine. Then when it comes time to rebuild you just need to pull the motor and do the machine work. Just means you need to trailer your machine to a mechanic its just boils down to convienience I guess.
The reason I didn't buy some other machines was because of the chinese diadong diesels run in some of them. Like Kioti. Heard a lot of good things about them. But my friend who I mentioned above his is broke all the time its a 55 hp machine It sit in his yard for the most part because he doesn't have the time to loose in the field. For the record his machine only has 3000 hours on it but I believe it was 12 years old when they were a realitivly new brand and machine.
You might be getting bad information ... Daedong (Kioti) is from S Korea.
   / Who builds Cabela's brand tractors? #32
Checking on how true the statement is that all the diesels other than Chinese have sleeves. At Caterpillar I do not believe we build any engines 7.0 liters or smaller with sleeves - they are all parent more. Just for kicks I checked the engine rebuild kits on a few JD CUT's and none of them supply sleeves either in the kit or as a service part. I know older small diesels had them but with improvement in block material things change. Also with customers demanding better reliability parent bore blocks began replacing sleeved blocks on a lot of smaller diesels many years ago. At Cat/Perkins when we changed the 4.0 and 6.0 engines to 4.4 and 6.6 liters we went from sleeved to parent bore but our small diesels introduced in the late 90s were all parent bores. Believe it or not on small engines it is less expensive to replace a block than replace sleeves whether wet or dry sleeve.
   / Who builds Cabela's brand tractors? #33
South Korea is about the same as Chinese in my opinion. lol. As far as engine building goes. My TYM is Korean but the only reason I bought it was because of the cat 2.2/ Perkins 404D. That's the only must have really is a quality engine and readily available parts.
   / Who builds Cabela's brand tractors? #34
Ok, no offense, but I'm going to stop taking anything you say as something worth listening to... You've lost your credibility with that one...
   / Who builds Cabela's brand tractors? #35
Ahhh yup. Could someone be anymore clueless and make more of a stupid statement then South Korea and Chinese are the same in his opinion.....well everyone can have their own opinion, but you have to take into account what else he thinks before listening to any advise.
   / Who builds Cabela's brand tractors? #36
Totally agree! It's statements like these that appear to be nothing but someone trying to get a rise out of others or completely clueless in regards to their manufacturing credentials and track record.
   / Who builds Cabela's brand tractors? #37
I have to agree 100%! Anyone who makes such a statement clearly has no clue!
   / Who builds Cabela's brand tractors? #38
The South Koreans are making some outstanding products on many fronts, tractors and engines being some of them. I don't have any tractors made there, but am impressed by what I hear from satisfied owners. There is no question that South Korea is on the quality tractor map.
   / Who builds Cabela's brand tractors? #39
I have a T450 and found a trans/hyd filter ( NAPA gold 1621) for I think $40.00 with AAA discount...
   / Who builds Cabela's brand tractors? #40
ok. Let me clarify my thought process a little bit. There are many parts that you can fix or repair on a foreign tractor if the fail and you can no longer get parts for with a little fabrication. Such as the, hydraulic system , controls, FEL's , you could have adapters made to run different rims if they were a strange bolt patern only used on a foreign productions. The one thing I realized is that the engine is the only part that would be almost impossible to replace if said tractor company went out of business. There is a set bolt patern on the bell housing. There is only one engine that is going to bolt up. While I realize There are companies out there that could machine adapters on a CNC machine to addapt a completely different motor to a foreign transmission the cost would be enormous. So to me weather the engine was made in Korea or China it wouldn't matter. The tractor manufacturer or the engine manufactuer could go bankrupt. Leaving you with no way to get parts or a replacement engine.
Secondly a foreign engine no matter where it was made wouldn't have a history of performance and reliability. Wich would affect the resale value. Like the Bellaruse tractors or nortrack tractors. I have seen people selling well running tractors at an almost give away price. Like For instance I saw a 60 H.P. Belarus tractor with 1400 hours the owner was asking 6 grand. It took him more than a year to sell it and he only got 3500 for it.
Now if you had a John deere engine, or a Cat engine or a Kubota engine in that foreign tractor. People would feel a little more at ease with buying a foreign tractor because they are known for reliable motors there is a sales and service network out there for the motors and parts are readily available. So it would put the buyer at ease.
For instance MTM. Is made in Korea But my engine is the Cat 2.2 / Perkins 404d. When I was comparing tractors. I could search the history of that motor. I found the problems that they had had and they had been corrected by Cat standing by their product and putting brand new replacement engines into machines that had problems. They had a standing T.S.B. to warranty with replacement engines until 2012.
The cause was faulty manufacturing and machine work at the factory where they were having the motors built. Odly enough the factory was in China. Lol. Anyways despite all the info that is available on the Lawsuit Cat had filed the point I am making is. If you don't know know the reputation of your engine maker it doesn't matter where it is made. It could be made at the North pole in Santas work shop and it wouldn't matter
25ft Tag Trailer (A56436)
25ft Tag Trailer...
UNUSED Wheeled Dump Hopper (A55272)
UNUSED Wheeled...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
Cargo Van (A59230)
Cargo Van (A59230)
