Why don't trailers have tongue casters?
   / Why don't trailers have tongue casters? #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
I've wondered this before, so now I'll ask. Is there some usability reason that no trailers have casters up front (perhaps a single one on the tow bar/tongue/term of choice) to help keep tongue weight off the tow vehicle? What reminded me of this was this trailer that I came across. (Attached image)
I have the desire for a dump trailer (small one) and a trailer big enough to haul my tractor. This could serve both purposes, but the tongue weight would be very high with my tractor on it.
   / Why don't trailers have tongue casters? #2
Have you ever ran with a shopping cart? That caster would go crazy. Bottom line is you need a truck or SUV properly sized to handle the trailer its to tow. The only "crutch" is a Weight Distribution Hitch. Air Bags and Overload Springs are a Band-Aid for too small of a tow vehicle or a improperly loaded trailer.
Chris
   / Why don't trailers have tongue casters? #4
Trailer Toad, Tow Buddy, Easy Tow, Tuff Tow
All quick items I came across on Google that should give you some ideas. I've never tried any of these, and some/most look to be geared towards the RV market.
-rus-
   / Why don't trailers have tongue casters? #6
The tongue casters would not make any difference in sway vs. a normal overloaded trailer. Turntable steered trailers work very well, especially with high center of gravity loads. At my former employer we used to make them, they ride like a charm and need half the tow vehicle weight, for an equally stable ride.
I've never seen them on your side of the Big Pond..
   / Why don't trailers have tongue casters? #7
Usually steered trailers resemble wagons.:)
   / Why don't trailers have tongue casters? #8
The nearest I've seen to what you are describing is with a specticle lift on a small recovery truck back in the late 80's. To save overloading the truck's rear axle towing a large car the lift arm had a big caster wheel under it.
The other thing has been heavy haulage semitrailer used with a dolly.
I did once almost have a castor wheel on the drawbar of my trailer. I forgot to wind up the landing wheel when I set off. It is amazing how difficult it is trying to remove a bent landing leg and wheel at the road side.:D
Interesting stuff here.
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A59904)
2016 INTERNATIONAL...
iDrive TDS-2010H...
