Why don't trailers have tongue casters?
   / Why don't trailers have tongue casters? #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
I've wondered this before, so now I'll ask. Is there some usability reason that no trailers have casters up front (perhaps a single one on the tow bar/tongue/term of choice) to help keep tongue weight off the tow vehicle? What reminded me of this was this trailer that I came across. (Attached image)
I have the desire for a dump trailer (small one) and a trailer big enough to haul my tractor. This could serve both purposes, but the tongue weight would be very high with my tractor on it.
   / Why don't trailers have tongue casters? #2
Have you ever ran with a shopping cart? That caster would go crazy. Bottom line is you need a truck or SUV properly sized to handle the trailer its to tow. The only "crutch" is a Weight Distribution Hitch. Air Bags and Overload Springs are a Band-Aid for too small of a tow vehicle or a improperly loaded trailer.
Chris
   / Why don't trailers have tongue casters? #4
Trailer Toad, Tow Buddy, Easy Tow, Tuff Tow
All quick items I came across on Google that should give you some ideas. I've never tried any of these, and some/most look to be geared towards the RV market.
-rus-
   / Why don't trailers have tongue casters? #6
The tongue casters would not make any difference in sway vs. a normal overloaded trailer. Turntable steered trailers work very well, especially with high center of gravity loads. At my former employer we used to make them, they ride like a charm and need half the tow vehicle weight, for an equally stable ride.
I've never seen them on your side of the Big Pond..
   / Why don't trailers have tongue casters? #7
Usually steered trailers resemble wagons.:)
   / Why don't trailers have tongue casters? #8
The nearest I've seen to what you are describing is with a specticle lift on a small recovery truck back in the late 80's. To save overloading the truck's rear axle towing a large car the lift arm had a big caster wheel under it.
The other thing has been heavy haulage semitrailer used with a dolly.
I did once almost have a castor wheel on the drawbar of my trailer. I forgot to wind up the landing wheel when I set off. It is amazing how difficult it is trying to remove a bent landing leg and wheel at the road side.:D
Interesting stuff here.
Year: 2014 Make: Acura Model: MDX Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 183,948 Plate: (A59231)
Year: 2014 Make...
1999 Thompson H3 S/A Towable Vacuum Water Pump (A59228)
1999 Thompson H3...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
2007 Frienghtliner B2 School Bus (A59230)
2007 Frienghtliner...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
