Scrounger
Platinum Member
It's pretty simple.
Use a torch.
Then a hammer.
Then a torch again.
OR
Buy a new tractor.
Use a torch.
Then a hammer.
Then a torch again.
OR
Buy a new tractor.
GeauxLSU said:OK, just to be clear since I don't think some are appreciating the amount of force I applied....The remaining tube is LOOSE. It can rotate 360 degrees and VERY easily swivels side to side. The amount of force I put on it (with the long 2x4 and leverage), I feel very confident was way more than I'll be able to put on it now since I have little/nothing to wedge under. Obviously it was strong enough to rip the tube apart. If I remember correctly the tip should be adustable based on what some of you are saying so I'm guessing that is option one if I can get some tools in there to grip the nuts. I've never removed the loader and am not really omfortable doing that without a mentor to witness it (and potentially report relevant details to the EMTs
Lopezian - you probably read about my auction experience. Is was not ideal. However, I was clearly informed here, that it was due to my own ignorance so I should just shut up about it. I'm trying to heed that advice despite this thread admitting as much yet again....![]()
irwin said:It's been four days since you last posted about this problem GeauxLSU, Well what happened ? did ya get it unglued? some closure please
2228 people have checked this thread out. let them know how you made out.
OK, I got back over there Sunday (sorry hadn't checked the boards) with my brother who was visiting from out of town and showed him my predicament. We tried bending the remaining tube 90 degrees under some misguided notion of his that that would allow for better griping and leverage.irwin said:It's been four days since you last posted about this problem GeauxLSU, Well what happened ? did ya get it unglued? some closure please
Alittle pressure and a lot of finesse is the most I've had to do with the thousands of zerks I've greased at work..finish that maint. and back to work.GeauxLSU said:OK, I got back over there Sunday (sorry hadn't checked the boards) with my brother who was visiting from out of town and showed him my predicament. We tried bending the remaining tube 90 degrees under some misguided notion of his that that would allow for better griping and leverage.When that predictably accomplished nothing he said "Why not just wedge a big flat headed screw driver tip between the fittings and twist?" I said, "No way I could put more pressure with a screw driver than I did previously when I broke the thing." I did it anyway to appease him and..... it came off 2nd try!
Well, maybe he's my OLDER brother for a reason?
GeauxLSU said:it came off 2nd try!
GeauxLSU said:Part two? Now after greasing all the fitings I could find, the lift arms won't lower the bush hog consistently? It will eventually drop but it used to operate without a flaw.![]()
GeauxLSU said:Thanks guys. Will do. It wasn't 'accidentally'. I thought it was.... nevermind....![]()
TRUKFXR said:JUST STUMBLED ON THIS THREAD. DON'T WANT TO ADMIT TO HOW MANY
YEARS I HAVE USED A GREASE GUN, BUT I NEVER KNEW THE TIP WAS
ADJUSTABLE. THAT EXPLAINS A LOT OF PROBLEMS I HAVE HAD IN THE PAST WITH TOO TIGHT FIT OR IN SOME CASES TOO LOOSE.
BillyP said:All I want to know is how do you adjust for fit cause I sure didn't know either![]()
