biker128pedal
- Joined
- Jun 16, 2006
- Messages
- 75
- Location
- Middle Peninsula Virginia
- Tractor
- Kubota B7610 and JD LT155
Sound like the threads were not tapped all the way through in the pan and the bolt pressure on the unthreaded material got somewhat welded/gauled to the bolt.  When you backed out the blt of extra material tore up most of the threads.  You were able to hand thread it in a few turns.  In hind site you should have stopped when it was hard to remove or when it became hard to turn when installing and then called the dealer.
I have had parts made that this happened. Lucky the shop was able to chase the threads clean and use a new bolt.
There is not real way to place the blame unless you cut it up and inspect it. Most likely they will find an overize bolt to install or use a helicoil.
Mike
Mike
