bgott
Veteran Member
I went back and took a closer look at your pictures and I think I see your problem. It looks like they sealed your gearbox with clear silicon. Clear silicon isn't gasket grade, that stuff is for sealing windows and shower stalls. I don't know what it's heat rating is but it's got to be next to zip. If the tech who worked on it used silicon on both sides of the gasket it probably blew a corner out when he tightened it. If you are going to use silicon buy the thick gasket maker stuff and leave the gasket off, if you have a void to fill and want to use a gasket, glue the gasket to the removeable part with gorilla snot ( 3-M weatherstrip adhesive) and let it dry completely. Then use the black, not clear silicon to fill the void. Wet silicon is a lubricant, it will let the gasket blow out. I use black for normal sealing and red for high temp, I believe it looks a little more proffessional that way. Ain't nothin' says a jackleg worked on it like a fat bead of blue or red silicon sticking out around a waterpump or a valve cover! /forums/images/graemlins/mad.gif
