Work Light Out
/ Work Light Out #1
bcp301
eastern massachusetts
BX-2230
Hi All
Can anyone tell me how to change out one of my work lights mounted on roll bar? Pics included. I believe it's a one piece cover and bulb but am curious how/where to get a replacement? From Kubota dealer perhaps? If it's not a one piece unit how to rewire bulb? How to remove from casing?
Thank you!
Brian P
/ Work Light Out #2
deete please. duplicate post for some reason.
/ Work Light Out #3
A couple pics of the back and undersides side would be a big help.
/ Work Light Out #4
I don't have a Kubota but have seen similar lights. Look around the outer circle of the bulb itself. The ones I've seen have a wire snap ring that holds the bulb in. If yours has this ring you'll need a small screwdriver or needle nose pliers to get it out. Once the ring is removed the bulb will fall out.
/ Work Light Out #5
The bulb just prys out of the rubber housing with the help of a small flat tip screw driver.
/ Work Light Out #6
Looks a lot like my backup light. Mine disassembles just like George2615 (post #4) says. The bulb is a one piece unit and plugs into a plastic fixture on the end of three wires. Replacement bulbs available at NAPA.
/ Work Light Out #7
I had sealed beams that looked a lot like that on my previous tractor. Available from Tractor Supply for about 10 or 12 dollars. Another route to go if you can't seem to extract a bulb from the current set-up.
Frank
/ Work Light Out
Yes, it appears to be a sealed beam - available from MD Tractor Parts for about $12.00 Thanks to all!
2008 Peterbilt 379 Semitruck (A64047)
2008 Peterbilt 379...
2002 International 9200i Truck (A61307)
2002 International...
2014 VOLVO VNL (A63569)
2014 VOLVO VNL...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
2022 Coyote Renegade Trailer (A63116)
2022 Coyote...
2016 Case IH Magnum 310 Tractor (A64047)
2016 Case IH...
