Work Light Out
/ Work Light Out #1
bcp301
eastern massachusetts
BX-2230
Hi All
Can anyone tell me how to change out one of my work lights mounted on roll bar? Pics included. I believe it's a one piece cover and bulb but am curious how/where to get a replacement? From Kubota dealer perhaps? If it's not a one piece unit how to rewire bulb? How to remove from casing?
Thank you!
Brian P
/ Work Light Out #2
deete please. duplicate post for some reason.
/ Work Light Out #3
A couple pics of the back and undersides side would be a big help.
/ Work Light Out #4
I don't have a Kubota but have seen similar lights. Look around the outer circle of the bulb itself. The ones I've seen have a wire snap ring that holds the bulb in. If yours has this ring you'll need a small screwdriver or needle nose pliers to get it out. Once the ring is removed the bulb will fall out.
/ Work Light Out #5
The bulb just prys out of the rubber housing with the help of a small flat tip screw driver.
/ Work Light Out #6
Looks a lot like my backup light. Mine disassembles just like George2615 (post #4) says. The bulb is a one piece unit and plugs into a plastic fixture on the end of three wires. Replacement bulbs available at NAPA.
/ Work Light Out #7
I had sealed beams that looked a lot like that on my previous tractor. Available from Tractor Supply for about 10 or 12 dollars. Another route to go if you can't seem to extract a bulb from the current set-up.
Frank
/ Work Light Out
Yes, it appears to be a sealed beam - available from MD Tractor Parts for about $12.00 Thanks to all!
2018 MACK CXU (PINNACLE) (A63569)
2018 MACK CXU...
LOOK! (A63109)
LOOK! (A63109)
203201 (A60429)
203201 (A60429)
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
Adams 5T Spreader (A63118)
Adams 5T Spreader...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
