Wrong hydraulic oil causing too much resistance in hydraulic pump?
   / Wrong hydraulic oil causing too much resistance in hydraulic pump? #1
TimBuck2
Bronze Member
Central Massachusetts
Kubota L4310 HST and Ford 841
I have a 30 year old Gravely zero turn mower with very little time on it (about 350 hours). I finally decided to change out the hydraulic oil and filter. I used what I had on hand for oil - Walmart SuperTech tractor transmission and hydraulic oil.
It took a while for the system to fill up (judging by falling level in in the intake side of the tank).
I believe all the air pockets are gone. The machine is up on jack stands, and the wheels are turning.
However, when I tried to run them full speed there is too much resistance in the hydraulic pump, and the engine starts to die.
The manual calls for using 20W-50 oil. I can't find any info on the viscosity of the SuperTech. If I can assume it is in the ballpark of by Kubota UDT specs, I am thinking it is something like 50 on the very pleasant 70 degree day
Anyone know whether this symptom is from too the oil being too viscus, or not viscus enough?
Any ideas appreciated before I start all over and see if the right oil was the right way to do it.
Thanks, Tim
Thanks.
   / Wrong hydraulic oil causing too much resistance in hydraulic pump? #2
I doubt if the problem is the oil. 20w-50 is a litte more viscous than what it calls for, but at room temperature it is basically a 20 wt oil and that is close enough to what you put in that it should work. If anything, I'd expect the Walmart SuperTech to be better.
No ideas other than I'd look elsewhere than the type of oil.
Thanks rScotty you are correct. I drained the SuperTech and replaced with 20W-50 and, if anything, the problem is worse now.
   / Wrong hydraulic oil causing too much resistance in hydraulic pump? #4
Maybe if you described the problem in more detail....
Has it happened before? What does "engine starts to die" mean? Won't rev? Hold revs? Backfires? Shuts off? Does it go to idle, or just stop running? And is all this with drive engaged or not.
   / Wrong hydraulic oil causing too much resistance in hydraulic pump? #5
Very doubtful that the oil is the problem since pressure is created by resistance to flow. Should be bo resistance with wheels in the air so suspect some problem with something mechanical binding like brakes or the engine itself.
Will the engine run full throttle without wheels turning?
The hydraulics were fine before I changed the oil and filter. The new filter is OEM from a Gravely dealer (thought I will triple check the part no. today).
After refilling the system,
- the engine runs fine,
- when I engage either or both wheel hydraulic motors the engine starts to start to bog down, and bogs down from too much torque from the hydraulic system. The further I engaged either hydraulic valve, the more the engine bogs down.
- at first neither wheel would turn, once the air pockets were gone, both wheels turn but if I engage either valve further the engine bogs from too much torque from the hydraulic system, and the engine will die if I fully engage either hydraulic valve.
Each wheel has its own hydraulic pump with the valve built in.
The system has an heat exchanger for cooling.
I need to trace the system and get a handle on where all the parts sit in relation to one another.
Thanks gents,
Tim
   / Wrong hydraulic oil causing too much resistance in hydraulic pump? #7
My hyro doesnt use hydro oil, it uses a synthetic engine oil, as I recall, most do not use hydraulic oil. I have Parker transmissions
   / Wrong hydraulic oil causing too much resistance in hydraulic pump? #8
Have you tried taking it off the jack stands and running it on the ground?
That occurred to me, that perhaps the problem is not enough resistance against oil flow. But I have not tried it yet.
   / Wrong hydraulic oil causing too much resistance in hydraulic pump? #10
Parking brakes aren't engaged are they?
Solved.
Langanobob nailed it. I took the mower off of jack stands and ran it on the ground. The hydraulic pump(s) made ugly noise for about 5 seconds, but then everything is started working normally.
Apparently hydraulic motors (or at least my set up) can't be "free wheeling" otherwise pressures build up in the wrong places.
Good thing to know!
Thanks again.
   / Wrong hydraulic oil causing too much resistance in hydraulic pump? #12
I think I’d stick the old hydraulic filter back on and try it. Just a guess but wrong or defective filter.
   / Wrong hydraulic oil causing too much resistance in hydraulic pump? #14
Solved.
Good thing to know!
Thanks again.
Solved.
Good thing to know!
Thanks again.
Where the wheels running at full speed when on the jack stands? Just curious since logic would say if everything was full of oil and stayed full of oil it should not matter if spinning free or not.
Glad it is working for you now.
When it was on the jack stands I would engage the hydraulic valve control for either wheel about 1/8 or less of the total lever/throw distance and the wheel would start spinning. It may have been spinning about full speed by then, but it was hard to tell.
Then as I moved the valve lever further there would be enough torque at the hydraulic pump that the engine would bog heavily, and by half way through the valve lever throw distance the engine would slow down and died in just a few more seconds.
If anyone has any ideas how running the hydraulic motors with no resistance / back pressure resulted in so much pressure and torque int he system I would be very curious.
   / Wrong hydraulic oil causing too much resistance in hydraulic pump? #16
Tim
I have no clue on how running wheels in the air would cause excessive pressure.
   / Wrong hydraulic oil causing too much resistance in hydraulic pump? #17
Have you bled the pumps? Raise the wheels off the ground open the "push with engine off valves" usually a hex head with a hole in it. Start and run engine while moving the control handles forward and reverse slowly.
Reason: The pump to motor circuit is a "closed" system, air can get trapped in this circuit and destroy the pump and motor. Opening the bypass screw allows the air to get out of this circuit. Check operators manual may explain the particulars.
   / Wrong hydraulic oil causing too much resistance in hydraulic pump? #18
Air in the system. Open freewheel valves and work the sticks forward to reverse a half dozen times. Close the valves and try it again. Repeat until it runs smoothly. I would definitely put the 20w50 back in it. When you get it heated up the hydraulic oil will be like water.
2023 MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
2023 MORBARK WOOD...
2022 WEILER S350 SKIDDER (A60429)
2022 WEILER S350...
GIYI SF60-60" HYD SIDE SHIFT FORKS (A60430)
GIYI SF60-60" HYD...
ANTHONY CARTS 94LFW-24 OXY/ACCELYNE TANK CART (A60432)
ANTHONY CARTS...
POLY TANK ON BRACKETS (A60429)
POLY TANK ON...
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 3,200 LB Crane Utility Truck (A59230)
2005 Mitsubishi...
