Yanmar 1500 head gasket
   / Yanmar 1500 head gasket
OK, I think I've got it.
I have the head in my car and am ready to start putting the pieces back together.
It will probably take me a couple of evening's to finish her up.
I will keep you posted on my progress and the out come.
A BIG heartfelt Thank You to all. You've all been a great source for information.
Sincerely,
Dave
   / Yanmar 1500 head gasket #52
Dr M said:
I have another question and this may sound stupid.....but all I know is that my tractor is called a....1500. Is that considered a YM155. It's a 2 wheel drive, 2 cyl, 17hp.
Dave,
To the best of my knowledge, the YM155 ( US ) and the YM1300 ( gray ) are the same.
Bruce
   / Yanmar 1500 head gasket #53
roxynoodle said:
The 3 digit (made for US market) tell you the engine horsepower. So a 1500 has 15 PTO hp, which is approximately 18 or 19 engine horsepower. A 155 has 15 engine hp, but probably more like 12 PTO hp.
Based on what is stated here I would say that the 1500 should be the same as the YM195. (19.5 Hp). Looking at the shop manual almost all the specs on the 195 and 240 are identical. I will measure the diameter on the cylinder head studs on my 240 today and post it for you. If yours is the same the torque value will be the same.
   / Yanmar 1500 head gasket #54
Marnus,
The YM195 = YM1700. I don't believe the 1500 has a US equivilent.
Bruce
   / Yanmar 1500 head gasket #55
It does not.
OK Folks,
I put the engine back together and it runs great. Started right up, running at an engine temp of 185 and all looks good.
I worked the tractor for approx 30 min. When I stopped and checked the oil it was a little milky (that is the way it looked before from water in the oil). I haven't had a chance to change the oil yet, but am hoping that it is just from the water jacket and the oil pump. I didn't see any loss of water from the coolant recovery system so I still have high hopes that I solved the problem.
Just wanted to keep you all posted.
Thanks again.
Dave
   / Yanmar 1500 head gasket #58
Glad to hear all is well!
   / Yanmar 1500 head gasket #59
Change the oil & filter & keep a check on it a few days . I Hope all works out well for you.
Hello Folks,
I am back at gathering more info to try and solve my Head Gasket?????problem.
i am still geting water in the crank case....is that always the head???
i think i will have to pull the head again and see if there is any sign of water trails in the gasket.
any other ideas before i start over.
thanks for all of your help.
Dave
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
SET OF (7) JACK STANDS (A53843)
SET OF (7) JACK...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
2015 Skyjack SJ 4626 Scissor Lift (A53117)
2015 Skyjack SJ...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
