Yanmar 3110D RPM's
   / Yanmar 3110D RPM's
Re: Yanmar 3110D RPM\'s
thanks. I followed the others advice and I just kinda went by sound and common sense where to stop. It ended up being right around 2200 so I guess I did okay. Now if I could just be sure my temp indicator is working I will be good to go.
   / Yanmar 3110D RPM's #13
If I remember correctly, If you ground the wire going to the sensor to the block , the light should come on as the light is hot when the ign. switch is turned on so, all that is needed is a ground.
   / Yanmar 3110D RPM's #14
tried it already. It most be in the wiring.
   / Yanmar 3110D RPM's #17
I had the same concern with my YM3000. I never saw the temp light so I was always concerned about overheating until one day.... I had replaced the belt and lost some coolant. I didn't think I had lost much so I added some water. Well I didn't add enough and low and behold there it was my temp light came on!!!! I let it cool off added more water and haven't seen it since. But I'm glad to know it works. /forums/images/graemlins/grin.gif
   / Yanmar 3110D RPM's #18
   / Yanmar 3110D RPM's #19
if you just bought it take it back to the dealer. (If it came from a dealer)
   / Yanmar 3110D RPM's #20
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2018 Jeep Grand Cherokee SUV (A51694)
2018 Jeep Grand...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2021 MACDON C3812 LOT NUMBER 34 (A53084)
2021 MACDON C3812...
