Yanmar 3110D RPM's
   / Yanmar 3110D RPM's
Re: Yanmar 3110D RPM\'s
thanks. I followed the others advice and I just kinda went by sound and common sense where to stop. It ended up being right around 2200 so I guess I did okay. Now if I could just be sure my temp indicator is working I will be good to go.
   / Yanmar 3110D RPM's #13
If I remember correctly, If you ground the wire going to the sensor to the block , the light should come on as the light is hot when the ign. switch is turned on so, all that is needed is a ground.
   / Yanmar 3110D RPM's #14
tried it already. It most be in the wiring.
   / Yanmar 3110D RPM's #17
I had the same concern with my YM3000. I never saw the temp light so I was always concerned about overheating until one day.... I had replaced the belt and lost some coolant. I didn't think I had lost much so I added some water. Well I didn't add enough and low and behold there it was my temp light came on!!!! I let it cool off added more water and haven't seen it since. But I'm glad to know it works. /forums/images/graemlins/grin.gif
   / Yanmar 3110D RPM's #18
   / Yanmar 3110D RPM's #19
if you just bought it take it back to the dealer. (If it came from a dealer)
   / Yanmar 3110D RPM's #20
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
7099 (A51573)
7099 (A51573)
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
