Yanmar 3110D RPM's
   / Yanmar 3110D RPM's
Re: Yanmar 3110D RPM\'s
thanks. I followed the others advice and I just kinda went by sound and common sense where to stop. It ended up being right around 2200 so I guess I did okay. Now if I could just be sure my temp indicator is working I will be good to go.
   / Yanmar 3110D RPM's #13
If I remember correctly, If you ground the wire going to the sensor to the block , the light should come on as the light is hot when the ign. switch is turned on so, all that is needed is a ground.
   / Yanmar 3110D RPM's #14
tried it already. It most be in the wiring.
   / Yanmar 3110D RPM's #17
I had the same concern with my YM3000. I never saw the temp light so I was always concerned about overheating until one day.... I had replaced the belt and lost some coolant. I didn't think I had lost much so I added some water. Well I didn't add enough and low and behold there it was my temp light came on!!!! I let it cool off added more water and haven't seen it since. But I'm glad to know it works. /forums/images/graemlins/grin.gif
   / Yanmar 3110D RPM's #18
   / Yanmar 3110D RPM's #19
if you just bought it take it back to the dealer. (If it came from a dealer)
   / Yanmar 3110D RPM's #20
2017 Case IH Magnum 380 ROWTRAC CVT Tractor (A53342)
2017 Case IH...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2008 Volvo XC90 SUV (A51694)
2008 Volvo XC90...
