YM226D Power Steering Rebuild
   / YM226D Power Steering Rebuild #51
Modern grapes are drip-irrigated at each vine. A few historic plantings remain that are dry-farmed same as the Romans did. They don't produce much but are prized for flavor.
I'm only 10 miles inland from the Pacific Ocean so the trees absorb moisture through their leaves, from the fog that blows in most nights in the summertime. Its normal for the sky to finally clear around 11 am.
This coastal belt is one of the few regions that dry-farms apples. Farther north in Washington State, irrigation for apple orchards is common.
   / YM226D Power Steering Rebuild #52
Digging up this oldie to see if Smoody was still around with an outcome. I have the same cylinder on a 330D and its been doing this 'squirting' thing for years, but I think its getting worse.
   / YM226D Power Steering Rebuild #53
Farther up in this thread is a link to another thread
http://www.tractorbynet.com/forums/yanmar/218151-anyone-have-pics-power-assisted.html
that discusses the same thing. There are pages from the PS manual - scattered across several posts - in that thread that should be sufficient to visualize the repair.
In summary, O-rings, #11 in the diagram (two of them) are what leak. The one at the tip of assembly #15 is what lets fluid escape and go out the vent hole. Don't take apart assembly #15!!! It is factory-calibrated to not pull the steering left or right. It can be removed intact.
The difficulty I have encountered is the big nut that holds assembly #15 in place can't be turned by any reasonable force I can apply. I can't imagine how to clamp the delicate aluminum body casting in a way that would take the force needed to loosen that nut.
Also as I recall the manual and I think a prior poster said the large steering piston assembly has to be removed from the aluminum casting before removing Assembly #15. It looks to be in the way of turning the assembly #15 nut.
Gjamtrac in that other thread sounds like he has repaired these. He might have some advice. Looking at his prior posts I found this
http://www.tractorbynet.com/forums/...teering-hydraulic.html?highlight=#post3532774
where he says you remove the flat cover off the side of the PS casting and remove its internal parts, then unscrew the big nut to take out assembly #15.
Perhaps it isn't necessary to take the PS off the tractor to repair it.
Gjamtrac hello, are you out there? Help! :yell:
   / YM226D Power Steering Rebuild #54
California ? When you're not doing grapes and "homework" do you ever sit down ? ;)
   / YM226D Power Steering Rebuild #55
At the moment I'm stuck indoors with plenty of time to fool around online.
Yesterday I posted to another Californian's thread titled It's been HOT:
My ranch (orchard) is an hour north of San Francisco. The NWS weather station nearby recorded peaks of 118.4 and 115.6 degrees over the last two days.
I shut down and retreated to my home over in the Central Valley where I have competent A/C.
The photo below is the last project I completed before saying the heck with it and bailing out. The apple orchard is operated commercially by a neighbor along with his own larger operation. We have some family fruit trees interspersed. I stripped a couple of family trees including this little pear tree, to take home.
The usual breeze coming in from the ocean 10 miles west of the ranch finally resumed so the forecast high for tomorrow 79. I'm headed back over there in the morning.
   / YM226D Power Steering Rebuild #56
Sorry California, Apple's not grapes. It is Apple's right?:licking: Bless you and your hot weather. Been mid 60's /mid 70's back here in Pa.:thumbsup:
   / YM226D Power Steering Rebuild #57
... Apple's not grapes. ... Been mid 60's /mid 70's back here in Pa.
Yeah, I'm one of the last holdouts. Nearly all the neighbors have leased their land to ag contractors who converted to grapes and fenced their parcels. In some cases fencing the landowner out of the land he used to roam freely. Now the owners have a view off their porches that looks like endless vistas of factory farming. My mature apple orchard continues to feel like living in a forest. I like this better.
But I did have to finally fence last year. With the deer fenced out of everywhere else this had become the neighborhood zoo. I counted a herd of 18 at one point and generally 14 deer living here. Photos from the past: (1) (2).
In my prior post, see the caged 2 year old tree across the lane from the pear tree? Even cages didn't slow down the damage that deer did to new trees. They learned to climb on the cages and crush them to eat the tasty new buds. Finally, reluctantly, I gave up and agreed to fence the place so our replacement trees could survive.
Wow, 70's there? You are fortunate.
   / YM226D Power Steering Rebuild #58
If you start shooting them you won't have 18 at a time, there pretty smart!
Even here we have the last few days have hit 90 but night is low 60s or upper 50s. And have had highs in the low 80s some days
   / YM226D Power Steering Rebuild #59
Thanks California. I read through the manual pages posted but wanted to hear from someone who was brave enough to have done it/or have it done. Tofay I took some zip ties and a piece of inner tube to mitigate things.
   / YM226D Power Steering Rebuild #60
Today I took some zip ties and a piece of inner tube to mitigate things.
That works for me.
I too hope someone can show us how to take it apart without distorting that irreplaceable aluminum casting.
I put this on after I got the tractor home and cleaned up. It's not elegant but it ended the upward spurt that was getting all over everything.
And kinda related: The power steering control valve is larger than the tie rod it replaced. I've seen dents in the oil filter where it was touched by the P/S in at full steering lock, and likely with extreme tilt of the front axle also.
So the little #1334 filter, 3 1/8 inches tall is the largest one suitable. There's an even shorter filter made for Subaru that would work too.
7ft Rotary Cutter (A57454)
7ft Rotary Cutter...
2009 FREIGHTLINER CASCADIA (A58214)
2009 FREIGHTLINER...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
2016 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2016 Nissan...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
NEW HOLLAND 105 WORKMASTER TRACTOR (A52708)
NEW HOLLAND 105...
