How to properly load a bumper pull deck over trailer?
/ How to properly load a bumper pull deck over trailer? #1
BrokeFarmerJohn
Columbus Ohio
2017 Mahindra 5555, John Blue G-1000, Massey Ferguson 98, John Deere GP
I have been looking at deck over trailers pretty heavily last few weeks (window shopping).
The trailer I would be interested in would be a bumper pull. All the deck overs have the axles so far back that it seems loading them without having a crazy amount of tongue weight, most loads would have to go on backwards?
I have had a 20ft deck over in the past, it’s axles weren’t as far back and I still backed quite a bit of the loads on backwards. Doesn’t seem to be as much of an issue with equipment trailers since axles are placed further forward.
Here’s an example, my Mahindra 5555 (80in wide, 15ft long with loader) is 7999lbs right now. The bush hog is 1025lbs but it’s 10ft long and 7ft wide. On a 25ft trailer I would have to back the tractor and bush hog on the trailer to get most of the load on the axles and not on the tongue? Not picturing a good way to balance the load with bumper pull. How much tongue weight do these trailers put on the truck?
I have read a few threads on here about this issue but non have answered my questions.
/ How to properly load a bumper pull deck over trailer? #2
The general rule is 10% of the total weight. If you have an empty trailer that weighs 1000lbs, your tongue weight should be 100lbs. If you have a loaded trailer that's 8000lbs, your tongue weight should be 800lbs. My max tongue weight is 1200lbs on my truck, which gives me a 12,000lb towing capacity.
Edit: That pickup is loaded wrong. Engine should be facing forward, it's where all the weight is. The bed weighs nothing, so it would be rear bias.
This happened in my town last fall.
I get the ratio of what should be on the tongue but with axles so far back I feel engine forward with tractor and bush hog or truck would put all the weight on the tongue of the trailer and exceed the limit. IMG_6798.JPG
/ How to properly load a bumper pull deck over trailer? #4
Center the load over the axels with forward bias. 10% is a minimum, you can load as much as your truck can take in the front though. Could be a 1500lb load and 1000lb tongue load, and it'll pull strait, but that's unnecessary load on your truck. Well balanced is 10% but you can certainly go over and won't run into any issues. Balance best you can, but 10% would be your minimum.
/ How to properly load a bumper pull deck over trailer? #5
Get a gooseneck. You won't regret it.
/ How to properly load a bumper pull deck over trailer? #6
First of all, putting the truck on forwards (correctly) doesn't put "all of the weight on the tongue". It's a weights and balance thing that any of you aircraft guys understand.
So let's look at that truck. On correctly, slightly forward of center, you have the rear axle behind the trailer axles and the front axle more so in front. If you want to get technical you can start measuring distances and calculate things, but realize that the trucks rear axle is a kid on a seesaw, the trailer axles are the pivot on the seesaw, and the truck front axle is the other kid on the seesaw.
We always want the fat kid on the front or tow vehicle side of the seesaw!
Now, just like that fat kid, if he weighs 150 lbs and the skinny kid weighs 120 lbs, the fat kid is only pushing down on his end with 30 additional pounds. Same with your truck or your tractor. And it's also a fine idea to measure front and rear wheel arches at the center point to the ground prior to loading. A good general rule would be to never load so heavy as to lift the front wheel arches over 3/4" - 1", this tells you that your getting heavy on the rear, taking weight off of the front axle and unless your using weight distribution (and you should) you have to careful about unloading that main steering and breaking axle.
But if you stood a 10,000 lb statue centered between the front trailer axle and the front of the trailer deck, your trailer will take on the strong majority of that load and transfer 30% at best to the truck. Of course I'm estimating since every trailer is built a bit different, but the axles are typically/generally around a 60/40 location, or centered 60% back from the front. Some are more, some less. But the coupler is feet yet ahead of that, so that further reduces that deck load seen by the truck.
Believe it or not, trailers are built with some thought to them. Your safe to load them properly as long as your not loading some really odd configuration that is extremely weight biased to one end. Your tractor and truck are not.
For the tractor, I've seen it repeated that you can consider the steering wheel to be the approximate center of weight, so make sure that the steering wheel is forward of the trailer axles a bit and you'll be fine.
So having the 8000lb tractor all the way forward on the trailer, front wheels prob 4ft behind the front bar and 10ft bush hog behind it is ok and won’t be too much weight on the truck? That would put the rear wheels of the tractor around the top of the front trailer axle.
/ How to properly load a bumper pull deck over trailer? #8
Might not be cool on a half ton, but I wouldn't flinch over that with a 2500/3500. You've got the tractor rears over the axle, the tractor front in front of it, and yet still feet back from the edge of the deck, and you've the mower that's likely 1000+ lbs behind the axles. Send it!
/ How to properly load a bumper pull deck over trailer? #9
I disagree!
The red GMC has the rear wheels at the very forward edge of the trailer.
The white Ford has the rear wheels at least 4' aft of the forward trailer edge.
Big difference.
The GMC ... LOOKS..... OK,...... but who really knows?
Only way to get the correct approximate 10% tongue weight, is to weigh the tongue.
Either truck on forward, would likely be excessive tongue weight.
/ How to properly load a bumper pull deck over trailer? #10
I would of backed the white ford forward more and I bet speed was a factor in that rollover........
/ How to properly load a bumper pull deck over trailer? #11
As Rock Crawler said, it's indeed a weight and balance thing.
Play with the setup till you have it just right. Even if that means stopping in the middle of a trip, to readjust, BTDT. Don't get the laziness get over you and disconnect the implements if necessary. I see most people will have mowers just hanging out the back, without any real reason as of why.
/ How to properly load a bumper pull deck over trailer? #12
The automotive industry designs for and expects "Level Frame" conditions for tow vehicle and trailer. Specification, design, and testing for this was part of my job. So, ball height, auto-level control, weight distribution, axle location(s), tire size and load capacity and bumper/hitch height specs are set by SAE. The wrong trailer configuration doesn't produce the safest journey. And, the legality of wrong hitch setups was established long ago. Much of this has to do with extreme stopping condition considerations. Even our State Police know about this and will stop you if your rig looks dangerous, especially tie-down mechanisms.
Get the trailer that does the job as well as the tow vehicle.
I disagree!
Big difference.
The GMC truck was a 2500hd 6.6 Duramax, extended cab with 8ft bed. It was as far back as I could get it, tank full of diesel.
Might not have been perfectly balanced but we made it to the garage it needed to go.
This was a F350 460 7.5L gas truck, lighter in the front. Dual rear gas tanks
IMG_1288.JPGIMG_1287.JPG this truck was wrong, F350 dually with 6.8 v10. 50mph max or trailer started to dance but wouldn’t fit on the trailer forward. Another successful tow just had to go slower.
/ How to properly load a bumper pull deck over trailer? #14
Looks like the flipped trailer was equipped with 3 axles but was operated with only 2. Plus the tires on the trailer look to be squashed. My expert witness testimoney would say that the truck trailer combination went unstable at expressway speed and jack-knifed. Tongue load is only 1 of the requirements. Sufficient tire lateral stiffness is another. Aftermarket cheap tires plus low air pressure plus speed above the 'critical speed' = jack knife. Not rocket science.
/ How to properly load a bumper pull deck over trailer? #15
I'd call this a nicely loaded trailer. John Deere 350C high lift on an Iron Bull 14K gross equipment trailer. Loaded forward of center, 60 PSI in the Airlift system. It's a heavy beast, you know it's there, no doubt. Getting paid $500 to deliver it 1.5 hours away tomorrow morning. I had to make plywood runners to put on my steel ramps, the steel tracks just slide off of steel ramps and can ruin your day really fast.View attachment 67264820201010_141253.jpg20201010_141207.jpg
/ How to properly load a bumper pull deck over trailer? #16
View attachment 672595 View attachment 672594
That is a rather high center of gravity, and a short wheelbase tow vehicle.
Could get really interesting at more than 70 kph on a rain slicked road!
/ How to properly load a bumper pull deck over trailer? #17
It's actually more stable than it looks up to 90 kph. Never went much above that.
The only time it got a bit sketchy on me was because I didn't load it quite right. Moved the tractor about 4 to 5" forward and everything was nice and stable again.
I've since replaced the 4x4 with a 2010 Mitsubishi L200 pickup truck as I got a good deal on it. Lost about 100 kg of towing capacity, but allows me to put an implement on the bed and relieve the trailer a bit more.
/ How to properly load a bumper pull deck over trailer? #18
What’s the weight distribution on your tractor? My M59 sits very back heavy. I have to pull the rear tire forward of the center of the axle to get satisfactory tongue weight. IMG_9144.JPG
What’s the weight distribution on your tractor? My M59 sits very back heavy. I have to pull the rear tire forward of the center of the axle to get satisfactory tongue weight. View attachment 672666
Not sure. It’s 7999lbs now and I’m about to add 300lb bolt on weights to each rear wheel and add a cutter bar on the bucket. That will put me around 8600lbs plus the weight of the cutter bar. The bush hog is 10ft long and weighs 1025 so total load will be under 9700lbs of payload. Might just have to make multiple trips lol. My buddies truck can only haul around 10k on the bumper, same as mine. Class 4 hitches. His has rails for 5th wheel, mine is just bumper.
Massey Ferguson 98 I have is 9500lbs just the tractor. So either way I’m towing 9500lbs of tractor whether I add weights to my tractor or not.
/ How to properly load a bumper pull deck over trailer? #20
With the loader on, it's gets a bit front heavy with all the front weight and winch sitting there.
Also, note that European trailers have the axles centered with the bed of the trailer. I do have to pull the tractor a little backwards so I don't end up with too much tongue weight but at the same time, I have to take the implement off so it doesn't hang out the back.
Most times, I just measure the distance between the rear wheel well to the ground unloaded, then load it till it drops about 2 to 2.5". Seems to work well and I get a stable rig.
CAT CB34 (A60462)
CAT CB34 (A60462)
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2011 Nissan Juke AWD SUV (A61574)
2011 Nissan Juke...
2022 John Deere 325G Track Loader (A63111)
2022 John Deere...
FORKLIFT (A56857)
FORKLIFT (A56857)
