New Holland 1725-1 4.50 star(s) (2)
Information, reviews, photos, discussion topics, owner pages, and specifications about the New Holland 1725-1.
Subcompact Tractors
About the New Holland 1725-1
New Holland 1725-1 Discussions (25)
Here are the most recent 1725-1 topics from our community.
  1. J
    Oil leak from "main gallery access port" in New Holland 1725
    I had oil spewing from this port the instant I started up my tractor. I'd been snowblowing on fresh snow the day before, so I know I hadn't dripped so much as a drop yesterday. The manual says...
  2. K5lwq
    New Holland 1725 PTO
    Was talking to my brother this morning and he has a problem with his 1725. PTO shaft quit spinning and opened it up to find this. Bearing spun and cracked the housing. He put it back together...
  3. R
    Price Check New Holland 1725
    My neighbor has a '97 New Holland 1725, 2wd that he wants to sell (he is moving). I have no idea what the tractor is worth. It has 900hrs and is in fairly good shape with service done every fall...
  4. B
    NH 1725 Hydraulics not working in cold
    Hey guys. I set my 1725 up for plowing after this storm, but couldnt get it started. So it sat for three days in sub-zero wind chills. Spent three hours getting it started, but when i did the...
  5. B
    Looking for AG rims and tires for NH 1725, can trade turf ones.
    Hello, I am new to this forum so hopefully this is the right spot to post it. I just bought a New Holland 1725 tractor with front industrial & rear turf tires. I found front 7 x 14 AG rims and...
  6. B
    My little New Holland 1725 caught herself a cold...
    Recently bought a 1725 with "supposedly" 640h on it. I know almost nothing about diesels or tractors (doubly about a diesel tractor) and my mechanical skill i slightly above "Oil Change" level...
  7. J
    new holland 1725 runs slow in every range and gear
    hello first time post 1st gear in range selector runs normal thru all 3 speeds 2nd gear only moves slow in 1st and second speed but rpms are way up 3rd gear moves slow in 1st speed and doesnt...
  8. M
    overheating NH 1725
    We have an overheating 1725 tractor with only 1700 hours. The radiator is leak and plug free, the thermostat is fine, and the pump seems to be fine (although I haven't pulled off the engine)...
  9. S
    New Holland 1725
    How many lbs of torque for head bolts?
  10. H
    New Holland 1725 oil and filter questions
    Hi, What kind of oil should I put in my New Holland 1725, what oil filter and air filter do i buy. Thank you so much. Tanya Somers, MT
  11. W
    New Holland 1725 Starter/Glow Plug problem
    I have a 1996 New Holland 1725, 4x4, approximately 1500 hours. I have had an intermittent problem with my glow plugs. Then, the glow plug indicator light would not light, and all I can do is...
  12. W
    Comparison 1999 new holland 1725
    I just bought a New Holland 1725 (1999) with backhoe and loader. It is the first tractor I have owned and I hope I haven't made a mistake. It has 478 hrs (supposedly) and seems in good shape. Is...
  13. D
    New Holland 1725 Starting problem
    I have owned the tractor for 9 years. (bought new) recently the key switch failed and I replaced it. At the same time starting was a problem. The glow plug light comes on. The tractor takes...
  14. G
    New Holland 1725 fuel shut off cable question
    I've gone through a couple of fuel shut off cables now, they all tend to break in the winter, they are stranded cables and I wonder if anyone has a permanent replacement or fix for the fraying...
  15. C
    Hydraulice Connection Backhoe to NH 1725
    This is a repeat of a question I asked a month or so ago. I got great help from several of you. Ductape said (paraphrasing) -----remove the power-beyond hose, run a new hose from the...
  16. C
    Woods BH70 HYDRAULICS to NH 1725
    I have a Woods BH70 backhoe on order (4 wks out) and need to get set up for attachment to tractor hydraulics. My loader uses the accessory ports on the OEM "diverter/manifold" leaving no obvious...
  17. R
    nh 1725 water in fuel
    hey all.working on a friend's 1725,found water in diesel by draining into a clear glass jar.drained all the fuel from tank,put in fresh diesel & managed to get it running good for a while then...
  18. D
    NH 1725 hood won't open
    I am trying to do some preventative maintainence on my tractor but all of a sudden I cant open the hood. The latch moves back and forth but won't release the hood. Is there anyone with the same...
  19. C
    Price Check Pricing a 1998 NH 1725
    I am looking to sell my 1998 New Holland 1725 2/w drive. It has 551 hrs on it. I want to find out what a good price would be. I am the original owner, it has been kept in a shed and it is in great...
  20. G
    1st time buyer -- Used NH 1725 ? Price OK?
    I've been reading for a while, I have 11 acres of old peach orchard and a house to landscape. Mostly will cut the field dig up rocks and push up dead trees. Also have lots of rocks to move...
[ad placeholder]
User Reviews (2)
Read what TractorByNet members think about the New Holland 1725-1 Subcompact Tractor
5
50 %
4
50 %
3
0 %
2
0 %
1
0 %
4.00 star(s)
myra
1725-1 New Holland
Owner
Model Year: 1999
Hi, NH is a 1925 model. Not sure what difference between the 1725 and 1925. The unit performs very well. Had 952 hrs. when bought, now has 1325. I do regular service and find it easy to work on. Have a soft cab with it. Would like to build one with the wrap around glass or plastic. Any got any plans or suggestings would be helpful. - tk myra
Pros: Great unit.
Cons: None.
5.00 star(s)
9zz
1725-1 New Holland
My First Tractor
Model Year: 2000
I'm a hobbyist tractor guy.... I really don't have anything to compare it to, it's my first tractor (a diesel 4X4 with 327 hours). I spend time on weekends using the tractor to support basic ranch operations (fence post holes, FEL tasks, road grading, mowing). The New Holland works well, is good on fuel (diesel), and always starts. Local dealer mechanic gave it a clean bill of health during the first routine maintenance call.
Pros: Goes up steep hills well and has ROPS.
Cons: It's 27 BHP. I'm guessing that at some point I may need more.
Photo Uploads:
New Holland 1725-1 Owner Pages
View owner pages to see photos, customization and comments about member-owner New Holland 1725-1s
New Holland 1725-1 Community Rankings
#31 user rating of 69 Subcompact Tractors items
#30 Viewed of 69 Subcompact Tractors items
#32 discussed of 69 Subcompact Tractors items
#999 user rating of 19625 items overall
#584 Viewed of 19625 items overall
#511 discussed of 19625 items overall
#14 Ranking of Most-OwnerPages in 19625 items overall
