Ford 3_150 4.00 star(s) (1)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Ford 3_150.
25-50 HP Tractors
About the Ford 3_150
Ford 3_150 Discussions (20)
Here are the most recent 3_150 topics from our community.
  1. F
    Ford 4100 lever valve addition
    Hi all (1st post) Wondered if anyone could advise. I’m in the process of adding a single (DA) lever valve to my 1977 Ford 4100 via the hv5902 adapter plate. My dealer recommended this Galtech Q25...
  2. B
    HV5902 installation guide on my Ford 4100
    I'm redoing all the plumbing on my tractor and loader. The hoses are old and cracked, and I also want to change up the loader valve and rear remotes. This is my tractor, late 70's Ford 4100. It...
  3. S
    Ford 4100 governor spring code
    Hi- I need help finding the governor spring code for my cav pump It has dpa numbber; 3233F641 cheers Svenn
  4. O
    Stripped transmission drain plug - Ford 4100
    I bought an 80's Ford 4100 diesel a couple of years ago and I need to change the transmission fluid. However the plug is stripped, so I can't get it out. It's the type with an inverted 1/2 inch...
  5. P
    Ford 4100 major oil leak from rear axle brake rod boot
    The old 4100 that I spent a lot of time on a year or so ago (rebuild thread here https://www.tractorbynet.com/forums/parts-repairs/386813-general-freshen-up-1967-ford.html ) has sprung a leak, it...
  6. P
    Ford 4100 hitch cannot be held in position (always raises)
    Hello, I'm at the point of buying a Ford 4100 (similar to 3000 & 4000 series), but there is one thing which refrains me: the three point hitch doesn't stop. Allow me to explain: If I lower it to...
  7. P
    What size slasher for Ford 4100?
    I'm in the market for a slasher and a little-used 6' unit has come up for sale nearby. I'm wondering if this would be too big to comfortably run with my Ford 4100, tractor is rated at 52hp.
  8. O
    Ford 4100 tool purchase advice.
    Which sockets or wrenches to buy? Might seem like a strange question but I recently purchased a 1981 Ford 4100 and don't have sockets that seem to fit. I was recently trying to take the cap...
  9. O
    Looking for wiring diagram for a 81' Ford 4100 Diesel
    As the title says I'm looking for a wiring diagram for the 4100 Ford diesel. I have the I&T manual which has a diagram for the gas but doesn't have the additional details for the diesel...
  10. O
    New member (and new to me Ford 4100) with some questions.
    I just bought a 1981 Ford 4100. I consider myself fairly mechanically handy, but this is my first tractor and have lots of questions. Also I've only had gas autos and equipment and the tractor...
  11. P
    What valve for Ford 4100 loader?
    As I continue the restoration of my Ford 4100 (see this thread ) I'm starting to look at the loader; the 2-spool valve is shot and I want to add a third function to the loader so I can run a...
  12. P
    Ford 4100 diverter valve- is one type better than another?
    I'm still wading my way through the refurbishment of my old Ford 4100, all of the hydraulic system inside the casing and the top cover are reassembled. I've come to stripping down the diverter...
  13. P
    General freshen up of 1967 Ford 4100
    We've had this tractor for about 8 or 10 years, it's been very useful for general work around the property like carting firewood, moving dirt and mulch etc but it was in a pretty poor state when...
  14. ILUVOZ
    FORD 4100 .. Column Gear Change
    I have recently gone wild and SPLURGED out to buy this dear old tractor.. Its a Ford 4110 and I have used it twice in the last two weeks since buying it , and broken it twice. 1stly I broke one...
  15. 5
    Comparison ford 4100 ,what year?
    Members... I have a ford 4100 with #B962734* and #6A23 above it. What year is it? It's a 3 cylinder diesel with alternator.Also any members have a wiring diagram of this tractor or know where I...
  16. CTPhil
    Ford 4100 Proofmeter Cable Drive
    I went to replace my proofmeter cable but am puzzled by what I found. I pulled out the old broken cable end and it had the part in the photo below attached to it. One end has a square hole and...
  17. Notforhire
    Ford 4100 charging system
    A friend called me today about his 1977 Ford 4100. The alt. warning light had been on, so he replaced the alternator. No change. I'm going to try to help him figure out the problem. Does any know...
  18. J
    Ford 4100 4 x 4
    Anyone know anything about the front hubs on the Ford 4100. Mine seems to have loose bearings, but on studying the service manual, it looks as if the bearings are straight ball bearings, not...
  19. T
    Oil leak 1981 Ford 4100
    I just found a new oil leak, pretty significant one at that. Wierd, it looks like it is coming from the top (left side) towrds the front from the HEAD GASKET. Leak is between the block and head...
  20. Chris2
    Price Check Ford 4100 good price or not?
    This will be my first tractor and I am looking at a Ford 4100 with a Koyker 200 loader with 6 foot bucket and a 6 foot bush hog, the tractor shows 4700 hours on it and the meter is broken, the...
[ad placeholder]
User Reviews (1)
Read what TractorByNet members think about the Ford 3_150 Subcompact Tractor
5
0 %
4
100 %
3
0 %
2
0 %
1
0 %
4.00 star(s)
jimb1
3_150 Ford
Ford 4100 4x4
Model Year: 1983
New Zealand Location - Tractor fitted with Twin Hydralic Remotes plus live pressure and return oil port underneath, and a 3 Way front blade (with own continuously live 3 lever control bank). This is an excellently balanced, versatile machine, with good security on steep hill country, and very good Hydralics. Possibly slightly underpowered, and the 3000 series power steering system is only just adequate. Have owned since new, and still very happy with the role it was purchased for. I have developed considerable knowledge of the features and quirks of the model.
Pros: Commonly available machine, so parts etc well available
Cons: Basic, and of limited power - does the job, but could do with some more "Bells and Whilstles".
[ad placeholder]
Ford 3_150 Owner Pages
View owner pages to see photos, customization and comments about member-owner Ford 3_150s
Ford 3_150 Community Rankings
#547 user rating of 2355 25-50 HP Tractors items
#1774 Viewed of 2355 25-50 HP Tractors items
#250 discussed of 2355 25-50 HP Tractors items
#1380 user rating of 19625 items overall
#6764 Viewed of 19625 items overall
#583 discussed of 19625 items overall
