Mahindra 7520_2 4.70 star(s) (7)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Mahindra 7520_2.
50-100 HP Tractors
About the Mahindra 7520_2
Mahindra 7520_2 Discussions (22)
Here are the most recent 7520_2 topics from our community.
  1. J
    Mahindra 7520 beeper mystery
    Hey folks. I have a 2007 Mahindra 7520 which I've owned since new. Recently it started intermittently beeping while in use, typically about 15-20 minutes after starting it. I've done all the...
  2. K
    Oil & Fuel 2008 Mahindra 7520 Hydraulic problem
    hydraulic fluid in engine oil i have a 2008 mahindra 7520 4wd tractor with front loader. i was doing some mowing and grubbing some small mesquite trees when i noticed my hydraulics getting...
  3. B
    Mahindra 7520/Loader
    Tell me a little about the Mahindra 7520/Loader. Will it have a power shuttle or do you have to use the clutch? 12 speeds, so is it a 4 speed trans and 3 speed transfer case? Durable? Does...
  4. J
    Mahindra 7520 front axle U-joint
    Hi. I have a 7520 4WD that's 10 years old and has about 1000 hours. The right front is making a squeaking noise when rolling. It's worse when it's cold, and will sometimes silence after using...
  5. S
    Oil & Fuel 2004 Mahindra 7520
    Hello. Needing some help with adding hydraulic fluid to a Mahindra 7520 . I just have bought this tractor, got it at a fairly good deal and trying to make sure all fluids and filters are ready to...
  6. C
    Need Help on Mahindra 7520 4WD (Electrical)
    Today while bush-hogging, the light on my dash that is the battery symbol came on. I turned tractor off several times and it started right back up but the light came on again every time. At...
  7. wbb
    Mahindra 7520 - fuel filler location / model year
    Hello, On my 7520 the fuel filler location is behind the seat. On some I see for sale on "Fastline" or "Tractor House" the fuel filler location is just forward of the left step. Also it 'looks'...
  8. M
    3-Point Hitch Mahindra 7520 4wd with 275 loader / lift arms don't work
    Dealer replace engine under warranty. Since replacement the rear 3pt lift arms has not worked. Oil and filters has been changed. All remotes been checked at 2600 psi. Lift arm levers are not...
  9. F
    MAHINDRA 7520 4WD front CV/ U JOINTS ..where to find cheaper ones?
    Ok my 2007 Mahindra 7520 4WD with almost 2000 hrs has bad front cv joints...specifically the cups/needle bearings are shot and that makes loud bangs when 4WD is engaged Anyhow my dealer tells me...
  10. J
    Trans oil for Mahindra 7520 4WD
    The oils that are specified in the owner's manual are not available locally for me. I had picked up a pail of chevron 1000 thf that I used, but I need more oil now. I have a NAPA dealer and...
  11. wbb
    Mahindra 7520 - Possible KSB issue - (bluish-white smoke / running rough)
    Folks, I need some help. I have a 2006 Mahindra 7520 FWA and loader. Currently it has 4xx hours on it. I really like the tractor as it is heavy and has a phenomenal FEL and 3-point lift...
  12. wbb
    New (to me) Mahindra 7520
    Hello all, New to me as of yesterday - a Mahindra 7520 Details: 2006 Mahindra 7520 164 hours FWA 275 FEL ( Mahindra Q/A ) would rather have SS but not much choice when you buy used. Paint isn't...
  13. X
    Comparing Mahindra 7520, Kubot M7040, Kioti DK65S
    I have a 60 acre mini ranch and raise cattle and goats. I move and feed round bales, do field work (discing, mowing, manure spreading), barn cleaning, occasional dirt work, drive grading, etc. I...
  14. C
    Cuz-Pat: My Mahindra 7520...I am sick of it!!!
    It has been nothing but one problem right after another since I bought it new in late August 2006. I now have 95 hours on it and have had more problems. Tonight I loaded it back up on my trailer...
  15. meyerwc
    Kubota M7040 4WD Vs. Mahindra 7520 4WD
    I am having a tough time deciding between a Mahindra 7520 4WD and a comparable Kubota M7040 4WD or M8540 4WD. My local Mahindra dealer (60 miles away) will sell me the 7520 4WD for $24,000...
  16. meyerwc
    Mahindra 7520 4WD Vs. Kubota
  17. meyerwc
    Advice on Mahindra 7520. 2WD or 4WD?
    I am considering purchasing a new Mahindra 7520 but I am not convinced that I need 4WD. I currently have a Ford 9600 with an FEL and a Case 1490. Both are 2WD. I have found that FELs can cause...
  18. C
    Mahindra 7520 Delivered Today!!
    I took delivery of my new Mahindra 7520 4 WD today. I got it with the ML 275 loader, skid steer quick attach adapter, skid steer 84" bucket, skid steer pallet forks, skid steer bale spear...
  19. P
    MAHINDRA 7520 "HEAT HOUSER"
    MAHINDRA 7520 \"HEAT HOUSER\" DOES ANYONE MAKE A "HEAT HOUSER" TO FIT THE 7520 MFWD W/LOADER? MY DEALER CAN'T FIND ONE. THEY TRIED TO FIT ONE FOR A 6500 AND IT WOULDN'T WORK. HELP, ITS GETTING...
  20. HayDR
    New Mahindra 7520 on display
    SUNBELT EXPO Pictures will be posted on Tuesday. Many dealers have them on order but have yet to see them delivered yet.
[ad placeholder]
User Reviews (7)
Read what TractorByNet members think about the Mahindra 7520_2 Subcompact Tractor
5
86 %
4
0 %
3
14 %
2
0 %
1
0 %
5.00 star(s)
swfarm
7520_2 Mahindra
Great Machine; Owner In Learning Curve
Model Year: 2005
This is a great machine. I am new to diesel motors and how they work. The maintenance book is good, but the best resource was their telephone rep who helped us through understanding the bells and whistles not mentioned in the model book. We find that knowledgeable service mechanics for these are hard to find. Call the factory in Texas and they might find someone to help you.
Pros: Great stout machine
Cons: Service technicians hard to find
5.00 star(s)
Anonymous Poster
7520_2 Mahindra
First New Tractor
Model Year: 2007
Best decision I have every made. Had been looking for a tractor for a couple of years. Always thought I could only afford 1/2 this much horse power. Five bt trailer plow, 12ft disc, and a 12 ft cultivator---it just plays with them. Put a snowblower on it and move old snow banks. Be careful it will keep going till it blows shear pins. Lift capacity is rated a 4000#. I lifted my haybine off the trailer. It weights close to 4000#. After loading the rear tires with beet juice I am able to move dirt with ease. Tractor is well balanced with a bucket of gravel backing out of the pit. Only photo I wished I had is of my tractor pulling a loaded fire truck out of a wet driveway.
Pros: Brute tough.
Cons: Dealer ship went out of business.
Photo Uploads:
3.00 star(s)
Anonymous Poster
7520_2 Mahindra
Okay
Model Year: 2006
Nice machine from the get go but goes downhill starting at 400 hours. I've replaced the starter grid heater relay and the fuel fill hose. The tractor is used for raking and hauling round bales sleeps inside. I don't expect to be working on a tractor with only 600 hours on it. I have another tractor w/5600 hours on it that's been worked on less. Not satisfied.
Pros: Cheap.
Cons: Get what you pay for.
5.00 star(s)
LJJ
7520_2 Mahindra
Excellent for the Bucks
Model Year: 2006
The tractor was purchased used (560hrs). It replaced a AC 5040 that had 3000 hrs and needed a lot of work (more money than it was worth). The Mahindra was a gamble, not many in this area. With low hours the question was why are they selling it? Turns out that it was used to clear land and was too big to cut the lawn after the house was built. It runs excellent. Good on fuel for an 80HP tractor and supplied much needed weight. Local dealers are 60+ miles away and sell mostly 25 to 40 HP units. Don't even carry oil filters. Would purchase another any day.
Pros: Strong, steady on slopes, easy to use for long hrs.
Cons: None yet.
5.00 star(s)
Rambelinman
7520_2 Mahindra
My mahinda
Model Year: 2006
Good tractor so far. One hiccup was the hydro pump went out at 20 hrs, but the dealer fixed it
Pros: I like the size.
Cons: Sometimes it's hard to start in extremely cold weather.
5.00 star(s)
Anonymous Poster
7520_2 Mahindra
MAHINDRA 7520
Model Year: 2006
It is a very good tractor. Wheel steering is very good. It is a stylish tractor but not AC and the cabin price was too high. Spare parts are hard to find in India.
Pros: MAKHU PUNJAB
Cons: MAHINDRA
Photo Uploads:
5.00 star(s)
Anonymous Poster
7520_2 Mahindra
Mahindra 75204x4
Model Year: 2004
This was my first NEW tractor. It is the best all around speced tractor of this size. It has been a very good machine for me. The only problems that I have had with it, (all after 400hrs) have been a PTO switch, a sticky brake light switch and a loose nut on the steering control box. All easily fixed, actually I have yet to fix the brake light switch, but I have the switch. The 7520 is a strong heavy machine and likes to be worked hard.
Pros: Came standard with a lot of items that other makes call options
Cons: rear draw bar is to low, although this has been remedied on newer models
Photo Uploads:
Mahindra 7520_2 Owner Pages
View owner pages to see photos, customization and comments about member-owner Mahindra 7520_2s
Mahindra 7520_2 Community Rankings
#124 user rating of 1508 50-100 HP Tractors items
#44 Viewed of 1508 50-100 HP Tractors items
#71 discussed of 1508 50-100 HP Tractors items
#788 user rating of 19625 items overall
#393 Viewed of 19625 items overall
#544 discussed of 19625 items overall
#14 Ranking of Most-OwnerPages in 19625 items overall
