Ford 800-1 4.50 star(s) (2)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Ford 800-1.
Vintage Tractors
About the Ford 800-1
Ford 800-1 Discussions (60)
Here are the most recent 800-1 topics from our community.
  1. F
    Will a Ford 800 motor fit in a 660
    The motor in my Ford 660 spun a bearing and I found a Ford 800 with a good motor in it . I'm wondering if the 800 motor will bolt in I know they are not the same C.I. but is the rest of the motor...
  2. centerline
    ford 800... need some support for steering box / power steering issues
    I purchased this old 850 a couple years ago, and for the most part, its a good tractor.... but someone has done a very shoddy job of installing a jackson power steering kit on it, and the wheels...
  3. F
    Ford 800 172 engine sleeves--Overbore or Std 3.9?
    I've owned my Ford 850 for over 40 years and it was last overhauled in 1970. It ended up getting submerged in a major flood and I plan to remove block, crank, and overhaul everything. I'm...
  4. K
    Ford 800 Power Steering Pump
    I am looking for parts or an entire pump for my Ford 800. It is a Thompson Products Inc. pump model P-1072. Any help on parts or resources would be greatly appreciated.
  5. R
    Oil & Fuel Ford 800 oil pressure
    Decided to tear down the 1958 Ford 800 to try and figure out my oil pressure issue, and I am scratching my head. She had 60 PSI of oil pressure when a quart overfull, but when at the full line it...
  6. B
    Ford 800 Starter Switch
    I have one wire from the push button starter switch to a single post starter solenoid ( solenoid also has the large cables from battery and to starter motor). Is the push button connecting the...
  7. T
    hello from Washington state ford 800
    i have a 1956 ford 800 with a 5speed transmission I have been told they make a roto gear that you can install to lower the gear ratio can any one verify this?
  8. M
    Ford 800 lever question
    What is this lever for? When I push up or down on it I can hear the oil pump go to work and my three point won't work for a minute until is "seems" like it builds up pressure again. Just haven't...
  9. M
    '58 Ford 800 Transmission oil level requirements
    I just inherited a very nice '58 Ford 800 with the five speed and live PTO option. The tractor has a loader on it that works fine and everything seems to work well except the 3 point hitch. In...
  10. Rock Crawler
    Help. Ford 800 1940's? Carb needed.
    I'm looking for this carburetor for my Father-in-law's old broken tractor. I need it with throttle and choke on the right hand side of the mounted carb (right side of carb as viewed from the...
  11. F
    Buying Advice ford 800 1957 live ptd best price used in excellent condition
    what is a fair price for a ford 1957 800 with live PTO double clutch no power stearing but excellent engine and tin
  12. B
    Ford 800 Remote Problem
    Directional control valve not working correctly. I can only get pressure in one line. And if I use that line to lift a load via a single acting cylinder, the load drops down pretty quickly when...
  13. Zebrafive
    Ford 800 series is it an 850 or 860?
    A friend bought a Ford 800 series. Is there an easy way to tell if it's an 850 (transmission PTO) or 860 (live PTO)? Such as PTO shaft will turn when in neutral (by hand) on 850, but not 860...
  14. B
    Ford 800
    Have a Forf 800. Never have used the aux hydraulics, ie, the couplers. Hooked up a single acting cylinder, one line, and i cant get it to move. I should be able to use a single acting cylinder...
  15. R
    Price Check Selling a ford 800
    Hello, we are trying to sell my grandpas tractor. He passed away we know it's a ford 800 but don't know how to find out what year. Would someone be able to help me and for a price I know he was...
  16. M
    Ford 800 finish mower size
    I have a Ford 800 that has had an engine rebuild and only has about 600 hrs on it. I was thinking of getting a Frontier 7' finish mower or an equivalent brand. Will my tractor run a 7 foot finish...
  17. S
    Ford 800 series Manuals
    I found the Ford 600/800 operators manual online, but was wondering if the I&T or Ford service and parts manuals could be located in digital format. I want the hard copies, but also want the...
  18. S
    Noob on a Ford 800 series model 8?0
    I picked her up from a Craigslist posting. Advertising as a 841, but even with my basic knowledge, new this was not correct. She has Five speed and live PTO, powered by EAF 6015J, which leads me...
  19. S
    Ford 800/801
    Does anyone have an 800 or 801 series that they would be will to measure the width and length of the center hood panel?I'm still unsure of exact model of my Ford, the serial number can not be...
[ad placeholder]
User Reviews (2)
Read what TractorByNet members think about the Ford 800-1 Subcompact Tractor
5
50 %
4
50 %
3
0 %
2
0 %
1
0 %
5.00 star(s)
ralpharvin
800-1 Ford
I'd Do It Again!
Model Year: 1955
So far, it's a fixable tractor. I have enjoyed learning about these tractors, as well as using it for plowing, discing, mowing, moving dirt and gravel, pulling logs, or just riding around my 5 acres. The tractor had been converted from 6v to 12v by a previous owner. I have had and currently am having an issue with the battery needing frequent charging. Other than that, some leaking around the rear end, but I don't intend to do anything about that for now. For an old tractor, it is very functional. I have purchased used equipment for it - plow, disc, pond scoop, grader blade, boom pole, and bush hog. I have less than $3500 in tractor and tools together. One of my wife's sewing machines cost more than that!
Pros: Enough power for my use. Easy on gas, too! Works best in long run situations, such as mowing, etc.
Cons: Steering wheel wears me out if I have to do a lot of maneuvering in tight spots.
Photo Uploads:
4.00 star(s)
canebreaker
800-1 Ford
Hydraulics
Model Year: 1952
They can be a little slow. Have to bleed the system before I can do any work.
Pros: It's okay.
Cons: It's okay.
[ad placeholder]
Ford 800-1 Owner Pages
View owner pages to see photos, customization and comments about member-owner Ford 800-1s
Ford 800-1 Community Rankings
#49 user rating of 679 Vintage Tractors items
#104 Viewed of 679 Vintage Tractors items
#13 discussed of 679 Vintage Tractors items
#998 user rating of 19625 items overall
#1285 Viewed of 19625 items overall
#250 discussed of 19625 items overall
