Jinma JM-304 3.30 star(s) (3)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Jinma JM-304.
25-50 HP Tractors
About the Jinma JM-304
Jinma JM-304 Discussions (32)
Here are the most recent JM-304 topics from our community.
  1. M
    Looking at Used Nortrac/Jinma 304
    Looking for a first tractor and stumbled across a 1996 Nortrac 304 with 579 hours and a Great Bend 240 FL for $6500. What's the consensus on these? I'll be using this for a 12 acre homestead...
  2. X
    jinma 304 pto clutch?
    I have a 2005 jinma 304. It seems that i have a single stage clutch withought realy knowing what i am looking at but all the manuals and instructionals i have found show the Access panel on the...
  3. X
    engaging pto on jinma 304
    Dose the pto on my 304 work via the clutch at all. When cutting hay i have to engage the pto and then start the engine With everything running. Is this korrekt or am i missing something?
  4. C
    Jinma 304 position control appears to be stuck
    I'm new to tractors, but I found a farmpro 2340 with a loader, backhoe and low hours. The backhoe is still attached, but I was reviewing the manual and getting acquainted with it. I attempted to...
  5. R
    Oil & Fuel Jinma 304 Water in Fuel
    Hi all, I need some guidance on an issue with my tractor. I went out to day to start it up and move it, and it barely started, running on what seemed to be only one cylinder and was pouring out...
  6. B
    Jinma 304 tractor was running with low pressure at idle. Now no pressure at all.
    My 304 has had low pressure when idling for a couple of weeks. When mowing of tilling at full RPM's the tractor was more or less fine. When I left idling the pressure would drop fairly low and the...
  7. W
    JINMA 304 from JESEF
    The price of the JINMA 304 seems very good. Anyone have experience with a Jinma 304 and/or JOSEF tractor?
  8. I
    Loader Hydraulic Bleeding Jinma 304
    I have a Jinma 304 and I have air in my front loader hydraulic line.....how can I bleed it off? Illarion on Vancouver Island
  9. R
    me and my jinma 304 tractor
    hi all:):confused2:
  10. R
    Jinma 304 Steering Set-Up
    A couple of days ago I was doing some brush hog work in the upper mango orchard and I noticed that my front end seemed a bit loose. That is, the steering was sloppy and that made me more than just...
  11. R
    Electrical problem, Jinma 304
    I was moving a bunch of trees and brush today and after a couple of hours I noticed the gauges had all quit working. I checked and the fuse for the voltage regulator was blown so I replaced, but...
  12. F
    Jinma 304 water pump
    Are there any tricks to putting a watterpump on this tractor that I should know about?
  13. A
    Oil & Fuel Low Oil Pressure in Jinma 304
    I've got a 2003 Jinma 304, with 430 hours on it. The oil pressure gauge has always registered just above the red zone, but yesterday it started straddling the red zone on the factory gauge. Any...
  14. Bama67
    Selling my Jinma 304
    Howdy guys, Well, I found out about a month ago I am going to be a Daddy, got my first one on the way. So I got to get rid of some things. I need to sell my tractor. It is a Jinma 304 4x4 (no...
  15. M
    Air Filter element on Jinma 304 needed
    Hello All, Does anyone know of a NAPA part number for a Jinma 304 Air filter element. I checked mine the other day and shook out lots of stuff, figured I better buy a new one as the old one is now...
  16. Bama67
    Good deal on Jinma 304?
    Hello guys, I am looking at a 2006 Jinma 304 with 60 hours, 6ft hawse bushog, and box blade. The tractor looks just like new. He said it has been excellent and had to do nothing to it. He says he...
  17. M
    Jinma 304 vs Jinma354
    Hello All, I am trying to get my clutch adjusted on my Jinma 304 and can mostly find procedures for the 354, WHAT exactly are the differences? Thanks in advance, Rick
  18. M
    Moving Large Round Bales with Jinma 304
    I have a Jinma 304 with a Koyker 160 loader, with a bale spear that attaches to the bucket. Periodically, I need to move round bales for our horses. I don't have difficulty picking up smaller...
  19. M
    Can't Engage 4WD on Jinma 304
    Can\'t Engage 4WD on Jinma 304 After using 4wd last weekend while turning my compost pile, I shifted back into 2wd. Now I can get it to return to 4wd, the lever moves a little but not all the...
  20. M
    Crossover Filter #'s for Jinma 304?
    Crossover Filter #\'s for Jinma 304? I understand that a NAPA Gold 1515 may work for the oil filter, does anyone have a crossover for the fuel filter for the 3 cylinder engine in the 304? As an...
[ad placeholder]
User Reviews (3)
Read what TractorByNet members think about the Jinma JM-304 Subcompact Tractor
5
0 %
4
67 %
3
0 %
2
33 %
1
0 %
2.00 star(s)
bgarretson
JM-304 Jinma
My 304 is a Constant Headache!
Model Year: 2006
I purchased my Jinma 304 in 2012 as a package deal with my 18 acre (2 acres in cultivation) farm. It was the worst decision I have made this year. From the start I have had one thing after another go wrong with it. The previous owner had to replace the block in it within 150 hours of use. After 250 hours of use the oil pump has gone bad. The 1st/reverse yolk in the gear box sheared off. The seal in the front left wheel has gone bad, spilling oil all over the rim. The hydraulics are weak as a kitten. I use a 5 foot tiller and bush hog with the tractor and I hardly have enough power to run them. I believe the concept of making a tractor that is half the price of a JD or Kubota is that you should just buy 2 so that you have 1 as back up when the first one breaks down, because it will. If you are considering buying one of these tractors please save yourself the headache and buy something reliable.
Pros: Haven't found one yet.
Cons: My kitten can till land better than my Jinma.
4.00 star(s)
happyj
JM-304 Jinma
JM-304
Model Year: 2004
This tractor does what I need it to do. I manage our horse paddock with it, grade my driveway, haul trees around with it to cut with my chainsaw mill and also firewood. I also have a post hole digger and am building fence for the pasture as I clear the land. Build quality is okay. You can tell the molds are worn and parts are not as tight as the JD's and Kubota's of the world, but I payed less than half the price of one of those and since I do not rely on it for a living it fits the bill. No features to speak of. I base performance on it doing what I require of it. I have not had any issues so far with it other than leaks and a brake problem. My dealer was a joy to deal with, he even brought a new tractor when the original one broke down in the field during the first week.
Pros: Cost.
Cons: None - it is just a bare bones tractor.
4.00 star(s)
Anonymous Poster
JM-304 Jinma
Jinma 304
Model Year: 2007
I bought this tractor as a crate unit and assembled it myself to learn a bit about tractors. I'm glad I did it that way, since there are no dealers or service places here in the Virgin Islands. I have to do it all myself, so I needed t know what I was likely to be dealing with. This tractor is a simple, no-frills workhorse that is pretty robustly built in most respects. The Chinese don't favor using heat-treated steels much, so many of the components are softer than I might like, but they seem to work adequately well. The tie rod is far too soft, however, and I had to reinforce it to stop it from repeatedly bending. Easy to do. The control valve that came with the Jinma ZL30 FEL was a total piece of crap and I replaced it promptly with one from RanchHand Supply and the difference is like night and day. The loader itself is okay, but the OEM valve was making it seem like a joke. I use the tractor for mowing orchards with a 5' brush hog, and it chews its way through 8' tall cane grass with no problems in low range. The 4WD is a godsend since half of the work I do is on hills that are fairly steep and/or in mud bogs. I've also used this tractor to move a 40' shipping container by pushing it across the ground. I was surprised at how easily it moved that heavy thing. This tractor is dandy for what I do. Plain, simple and no bling. I think shuttle shift would be nice, but it wasn't an option. This is a no-frills tractor, after all. It isn't the best machine ever built - there are some things that need to be done to make it better, like a bigger alternator, bracing for the fiberglass canopy, and other little stuff that I've done as I found time and energy. I don't mind having to do that since this tractor cost about half of what a similarly-sized Kubota or New Holland would have and does the same work. It's a very good value for the money if you don't mind doing a few things to improve it.
Pros: solid, reliable, simple
Cons: soft steel, canopy snags tree limbs, alternator is wimpy.
[ad placeholder]
Jinma JM-304 Owner Pages
View owner pages to see photos, customization and comments about member-owner Jinma JM-304s
Jinma JM-304 Community Rankings
#766 user rating of 2355 25-50 HP Tractors items
#251 Viewed of 2355 25-50 HP Tractors items
#189 discussed of 2355 25-50 HP Tractors items
#2186 user rating of 19625 items overall
#605 Viewed of 19625 items overall
#426 discussed of 19625 items overall
#2 Ranking of Most-OwnerPages in 19625 items overall
