Implement Dollies
   / Implement Dollies #1
kclark2227
Kannapolis, NC
Kubota L4701 4WD HST
I am wanting some dollies for my implements to sit on so they can be moved around the building easily. I am also wanting to work on my welding skills so I'll be welding them up. My question is does anyone have a strength chart for box tubing so I know what size tubing to get?
And if anyone has any photos to share that would be awesome also. I am looking to build some for box scrape, carry all, rear blade, FEL bucket and grapple.
   / Implement Dollies #2
I don’t have a strength chart (built all mine with 2x4’s). For shapes a carry all just needs a flat platform with wheels (like a furniture dolly). For my rear blade I used a ‘t’ shape with 3 wheels and blade guides on the top of the ‘T’ to stop the blade from falling off and a vertical section on the base of the ‘T’ to support the attachment point. For pic ideas bxpanded has some good designs. Don’t skimp on the wheels.
   / Implement Dollies #4
I built dollies for all my attachments using 1/8" x1.5x1.5 angle iron. make sure you get beefy enough caster because they roll around better if you do. The heaviest thing was a 850# ballast box and a 750# box blade. They still are a bear to push around.
I wouldn't worry about brakes on them. They are pretty stationary with all the weight on them.
   / Implement Dollies #5
True... I still put one of the four on my wheeled pallets as a brake. Just in case for some unforeseen reason. All four would be needlessly expensive.
   / Implement Dollies #6
Search results for: 'furniture dolly'
You wouldn't be able to buy much steel tubing and casters for the price of these. Could use a pair of them in tandem if weight was a concern.
Harbor freight has a 25% off coupon ending today. (Sunday)
   / Implement Dollies #8
I used 2x4's, 1/2" plywood, and screws to make the proper sized rectangles for each implement. HD has some nice 3" steel wheels that I screwed into the bottom for about $5 each and I can roll all my implements around my shop (concrete floor). I also bought a 2 car mover dollies from HF and attached a 2x4 across them to make a dolly for my tiller. They all work great, but will only work on concrete or asphalt.
   / Implement Dollies #9
These are a little different might spark an idea. They slide into the square tubing frame on my chipper.
gg
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56438)
Dual Tailwheel...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
KUBOTA ZG23F ZERO TURN LAWN MOWER (A60430)
KUBOTA ZG23F ZERO...
2014 Ford Fusion SE Sedan (A59231)
2014 Ford Fusion...
