Front or rear snowblower
   / Front or rear snowblower #21
Won't be too long and we will be out there playing (working) in the snow again.
Wayne
Too true. For the next couple of months I can still dig, move, mow, and chip, but in the winter the only such work (play) I get to do is snow related.
And I still have several more projects before I'll be ready to make that switch. :eek:
Jay
   / Front or rear snowblower #22
Figured I'd chime in on this thread - I have both a front-mount Erskine and for several years a seven-foot New Idea rear-mounted snowblower. Like YankeesFan I did the golf cart cab thing too. This year there's even a big comfy Laurin cab (I'll report on that after the snow comes).
From using both types I can say that front mount and rear mount each have their pros and cons. The rear mount shines on shorter curved driveways - its easier to feed into tight spots - but there is the side-saddle looking back thing. The front mount has the advantage on long straight runs - the front facing driving position is an obvious plus. But for curved paths the front mount should be a foot or more wider than the tractor - where a rear mount can be just a few inches wider and avoid packing snow down with the tires. The other issue with front mounts is whether they can float to follow twisty sloped surfaces. Some are rigid side-to-side and are best on flat surfaces.
   / Front or rear snowblower #24
I've found the electric chute to be pretty mickey mouse. I changed it to the hydraulic and love it.
I use the front blower on 800 feet of drive. From time to time if the conditions get bad I use a read blade just to loosen stuff up so the blower can get rid of it.
If you have it on the front you might want to use some flat black paint to reduce the glare from the head lights at night. You get lots from the snow anyway.
If you use a rear mount you'll have to mount lights on the back. You also better be young and not starting to get fusing of your spine. ( who? me? )
Twisting to watch behind you while you're making hay in the summer is one thing. Twisting in the cold with a big parka is another.
Blow it as far from your drive as you can at the very beginning of the season. If you plow or blow it beside the drive you're going to create a snow fence effect and the wind will fill it back in faster.
Good luck
   / Front or rear snowblower #25
Love to hear what you think of the Laurin cab - are they as nice as they look?
   / Front or rear snowblower #26
This isn't as nifty-looking as the cab they make for your M59, but here's a stock picture of the Laurin cab model for my tractor. I really like that it is so roomy, about 54" wide inside. It has tinted glass and the Laurin attention to detail is everywhere. Mine doesn't have air - but western Mass summers are reasonable and it has a huge fresh air blower. This older design has flat glass and heavy steel corner posts - For mowing this season I lifted off the doors and back windows. Laurin did a very nice job of fitting to the open-station L5450. This winter it will be quite a step up from my golf cart cover.:cool:
   / Front or rear snowblower #27
First off, no matter what, get a snowblower.
I plowed with a rear blade (going backwards) on my BX1500 for a few years.
Then, I stepped up to a 40-something" Meteor 3PH snowblower, and it was great.
I can see the advantages of a front mount, but I like having the FEL on at the same time.
It's not hard to remove, but I'm lazy.
The FEL can be useful to backdrag the garage door (I can't drive across the front of my garage), underneath the mailbox, and a few other areas.
I also use the FEL to carry my firewood box from the shed to the house during the winter. The rear snowblower makes a nice counterweight, and frees up the FEL.
I don't mind the backing up. We have about 700' of driveway, but it's just not a problem for me (yet?). Of course, I did the same thing with the back blade.
The shute has three "distance" settings. I use the middle one. It's not quite as impressive as the the "send to the neighbor's yard" setting, but it does keep the blowing down somewhat, and still gets the snow away from the driveway.
Another factor, as with all things related to snow clearing: The type of snow you get. In MA, we get quite a bit of fairly wet snow. Wet snow doesn't blow back in the wind as badly. So, it may be that those in, say, the uppper midwest or lake effect territory have a bigger blow back problem. Not that it never happens, but it's not this horrible thing. I do wear a hat, my prescription glasses, and a snowmobile suit. And there are times I get covered - but not that often.
Lastly, I have noticed how different people look at the phrase "clear snow". To some people, their driveway has to be black and dry. Others find that as long as it's passable, it's good enough. I usually don't plow when we get only a couple of inches. So, the "blade is good with smaller snows" argument isn't worth much to me. But, to others, it's a big deal. To each his own.
   / Front or rear snowblower #28
I'm in the same situation. Our drive is roughly 700' and with 100+ inches of snow last year the rear mount snowblower and my neck got a workout. It wasn't too bad because I could twist in the seat enough to stay comfortable. I bought my tractor used and it came with the blower and a cab and FEL. If I were looking at new I might consider a front mount.
Thanks for all the opinions with this.
Does anyone have experience with a snowblower on a stone driveway. The dealer mentioned that it may be a problem. We generally don't get a good frost in our area to freeze the ground so I have been known to push up a few stones with the FEL.
   / Front or rear snowblower #30
I am putting a front snow blower on my new L5740. Some of the snow work is going to be in/around buildings so it should be a lot easier to operate (steering the tractor, rotating the chute, tilting the chute deflector) compared to have one on the back. I also plan on having a 3pt hitch 7ft blade on back. I can use this to back into a buiding door way and pull the snow out to where I can handle it with the blower. Seems like a snow blower on front and blade onback should be a good plan. If not, I will just have to sit in the warm cab and listen to the radio til the sun takes over. This is my very first tractor with a cab so I hope these extra $ are being wisely spent.
My biggest concern is will the L5740 (with the Kubota 72" snow blower) be able to throw the snow out at least 35-40ft, and hopefully a little farther.
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
1459 (A57192)
1459 (A57192)
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
