Homemade Cab for Deere 2320 CUT
   / Homemade Cab for Deere 2320 CUT
You have done a very professional job that looks great. I cant remember if you spoke about it before but are you going to add some kind of heater so the windows dont fog up while blowing snow? Also did you think about adding a rear window wiper? I use my rear wiper more than the front when blowing snow. Also glad quality control passed the final product:D
Thanks.
I have a second wiper on the workbench, but haven't gotten time to drill the hole and attach it yet.
As for a heater, I haven't decided completely how I am going to do that yet. At this stage, with house selling and moving coming up, I'm sure a heater won't happen real soon. I may look to get a little fan to blow air on the windows to help fight the fog some. The temps are supposed to drop this weekend, so I'll be able to test out how things do in colder weather. The day I got the door on it was 60 degrees or so, not very good for testing the warmth of a cab! I almost wished for air conditioning at that point!
I've noticed that a good amount of engine heat gets picked up in the cowl/dash. Plus, a little fan blast does get through down by the pedals currently. I may look to do a heat houser type setup and avoid running coolant hoses back to the cab and such, will have to see...
   / Homemade Cab for Deere 2320 CUT #122
nice cab keep up the good work oh yeah around how much did all of your materials cost, i am thinking about making one fr my bx2200 keep the pics coming
   / Homemade Cab for Deere 2320 CUT #123
I haven't really noticed the flexing in the plexiglass when using it. I know it does flex, but it's at least not distracting. The weekend I got the RH "glass" in, we had a day with nasty winds all day. I had to move the tractor to do something else in the shop and was a little nervous about that much wind load on the big window. But, it didn't seem to bother it much at all. I think the "bend" in the cab helps some, that split in the windows siliconed back together gives it a little more stiffness than 1 completely flat piece.
The door itself is a bit on the flexy side though. The low mounted latch didn't help that much, but that was the easiest place to fit it in as things developed. If you hit a big hole or something, you can see the top of the door frame flex away from the cab frame a bit. Nothing rattles because of the weatherstripping, so that's good. A latch closer to halfway up would've helped that problem a lot...
Hope you stop drilled that crack before you siliconed the 'patch' as that crack will continue to grow with additional flexing. (if not, it is not too late, just drill small 3/32" hole exactly where the crack ends and fill with silicone)
In the aircraft industry, stop drilling a crack is the 'acceptable' repair scheme.
Also holes drilled in plexi should always be a size bigger than the fastener used to allow for expansion and flexing.
Thanks for the tips. I've heard about stop drilling cracks before, fortunatly haven't had the need to try it for myself yet. The split in the plexi that I refered to is there intentionally. The sides of the cab aren't flat, it bends about halfway up so the upper part is tapered inward a couple inches. Rather than build/find a strip heater and try to bend the plexiglass to match, I just cut the big windows at that bend, installed it in two pieces, and used clear silicone to rejoin the pieces at the "bend", aquarium style.
Update on cab function
Thought I'd give an update as to how the new cab has functioned so far this winter.
The first think I noticed over a month ago was that just blocking the wind makes a huge difference in comfort. I installed a cheap indoor/outdoor thermometer out of curiousity. It is almost always at least 4 degrees warmer inside the cab. If I run the tractor hard for an hour or so, the cab'll pick up a few more degrees. Since completing the cab, we sold our acreage and moved to a temporary rental house in town. Needless to say, I have the biggest, baddest snow removal equipment on the block! :cool:
This spring we'll be building a new home. Twice now, I've driven the tractor out to the building site, about 3 miles outside of town to blow or dig out the driveway so contractors, etc could come out to survey, etc. Both times, it was about 15 degrees out, and after dark. The first evening, I set a $7 ceramic heater from Wa-Mart in the cab for about 20 minutes before I left the house, just ran a cord out of the garage. In that time, the little heater had things up to 50-55 degrees inside the cab. I took off, was gone about an hour or so, and the temp never dropped below 20-25 degrees before I got back, never put my gloves or hat on the whole time! The second different time I ran out there, I didn't get home early enough to preheat the cab, but stayed plenty comfortable in there with coveralls and my Carhart coat on.
Windshield fogging hasn't seemed to be a big problem yet. Even when blowing snow, breathing pretty close to the rear window, I rarely have to wipe any fog off of the plexi. I think after the new shop gets built this summer, I'll think about adding a real heater, but so far, so good!
   / Homemade Cab for Deere 2320 CUT #126
I'm thinkin you just need a good long extension cord! ;)
   / Homemade Cab for Deere 2320 CUT #127
Great to hear that the cab is working out for you! Like you said just getting out of the wind and snow helps alot and the heat is an added bonus:D.
   / Homemade Cab for Deere 2320 CUT #128
I saw Harbor freight has little 12 v heaters for $10.00. Might just do the trick for you.Item # 96144.
   / Homemade Cab for Deere 2320 CUT #129
In order to use 12 v to generate heat means they are using an element (like stove) and that will draw MUCH to much amperage from an already marginal (most CUTS) electrical system.
You will run battery down in record time and maybe even damage alternator.
   / Homemade Cab for Deere 2320 CUT #130
You could buy a large one-wire alternator and connect it to the PTO. Need about a 3:1 pulley ratio. Connect to the tractor battery. You'd have so much power that those little 12vdc heaters would drive you out of the cab in fifteen minutes.
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
2025 TMA Attenuator Truck (A52377)
2025 TMA...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
